Author Topic: aaz diesel pump doesnt rev  (Read 2862 times)
April 28, 2009, 08:22:52 am
workz
  • 2
« on: April 28, 2009, 08:22:52 am »
Hi guys
pls help???sent my pump to get new seals  and pump serviced
got it back but it sat for 6 months before i put it back into the car
(redone the motor)and now he pump does not rev it just idles more a less
spoke to guy that done the service on the pump says i have to send it in again ($$$) cause it has cloged up dew to sitting for so long. :( any tips?
Reply #1April 28, 2009, 10:33:07 am
gigaz2
  • 626
« Reply #1 on: April 28, 2009, 10:33:07 am »
you need to time the pump, then calibrate it, it seems the "throttle" lever may be off as well.
if it idles its probably ok
Reply #2April 28, 2009, 10:46:21 am
« Reply #2 on: April 28, 2009, 10:46:21 am »
after i built my injection pump, i couldnt get it to do anything besides idle either. i bet the throttle arm is off a tooth or 2. and i bet the fuel screw needs to be messed with. i moved my throttle arm 1 tooth, screwed the fuel screw most of the way in, then voila, it lives. and im glad it works. biggest improvement ive made to my engine yet. its definitely gonna eat some hondas now.
Reply #3April 28, 2009, 08:04:46 pm
Hey
  • 339
« Reply #3 on: April 28, 2009, 08:04:46 pm »
Don't send the pump to this guy again!
Jetta 96, VG-mTDi/hybride td, 20psi, IC, 10mm camplate de tdi, .205 et CTN
Reply #4April 29, 2009, 11:08:00 am
workz
  • 2
Thanks
« Reply #4 on: April 29, 2009, 11:08:00 am »
Ok guys thanks  for the info will try set it up right :D hopefully will be back on the road soooon... :P
