Author Topic: turboing a non turbo 1.6?  (Read 6681 times)
September 01, 2005, 07:58:19 am
fillmore
  • 60
    • http://fillmorenorthband.tripod.com
« on: September 01, 2005, 07:58:19 am »
is it possible to turbo a straight 1.6? ive got a motor in great shape, i juat did the rings, gaskets and valve seals but rust got the best of the floor so the shell of the car is no longer good to me, i did however just pick up a very mint 89 jetta gasser and i was thinking about swaping out the engine next summer so is it possible to turbo the non turbo 1.6 diesel engines? all i can think of is the turbo, the manifold, intercooler oil lines to the turbo but what else would be involved if it is possible? wastegate perhaps?
Reply #1September 01, 2005, 08:57:47 am
BlackTieTD
  • 1512
« Reply #1 on: September 01, 2005, 08:57:47 am »
you're much better off finding a complete 1.6L turbo diesel setup and swapping the works over.
you could try to turbo what you've got but, i wouldn't.
Reply #2September 01, 2005, 11:23:35 am
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
« Reply #2 on: September 01, 2005, 11:23:35 am »
You could but i think that won't be lasting too much...
Excuse me on my bad English
Reply #3September 01, 2005, 11:54:19 am
vwmike
  • 1158
« Reply #3 on: September 01, 2005, 11:54:19 am »
IF you do it the biggest thing you need to watch is exhaust gas temperatures. Especially climbing long grades they can get really high and since the N/A engine doesn't have squirters it cannot cope with the high temperatures as well as the TD engine can. You could end up with melted pistons and/or cooked rings.
Reply #4September 01, 2005, 02:19:53 pm
« Reply #4 on: September 01, 2005, 02:19:53 pm »
you're best bet would be to get a nice small turbo, bigger exhaust, and an IC, and an EGT gauge (and possibly oil temp/pres gauge?)
as long as you don't drive it like an idiot it should hold up.
just remember don't get a big turbo... they take a longer time to spool and usually inrease egt's by a lot more than a small less restrictive turbo such as a K14
and like anyone else will add.  Don't mess around too much with fueling if you're going to do this!!!
Reply #5September 01, 2005, 06:08:58 pm
Northboundtrain
  • 131
    • http://boulderbiodiesel.com
« Reply #5 on: September 01, 2005, 06:08:58 pm »
Quote from: "jtanguay"
Any suggestions on where to find a K14?
'75 Chevy 3/4 ton 6.5L conversion
'91 Jetta 1.6L NA
Biodiesel
"The fool who persists in his folly will become wise." -Blake
Reply #6September 02, 2005, 02:35:31 am
entuzijast
  • 73
« Reply #6 on: September 02, 2005, 02:35:31 am »
Eco diesels (1V) and some of the strongest diesels with 80Hp came with K14...
Reply #7September 02, 2005, 04:09:25 am
« Reply #7 on: September 02, 2005, 04:09:25 am »
which basically comes back to BlackTieTD's recommendation of trying to find a complete engine.  You can definitely try the wreckers, but you'll mostly find the bigger turbo's if any at all.
Reply #8September 02, 2005, 04:41:19 am
DieselMonkey
  • 124
why not a GT15 or K03 ?
« Reply #8 on: September 02, 2005, 04:41:19 am »
A Garrett GT15 or KKK K03 would be a better turbo. They use a differet bolt-up arrangment than a K14 or Garrett T2. My Eco has a K14 and its pretty good, but with 15 years on it, 122,000 miles it is starting to weep at the compressor housing, possibly blow-by though.
I have 2 GT15's (no matching manifolds), 1 K03 with 4 matching manifolds and a Garrett T2 with no maching manifold. If you have trouble getting a turbo, i would consider selling one. You'll really need a EGT gauge. Contact Evan at 42 Draft designs.
[email protected] .....its a VDO unit costing $135 with gauge and probe.
I've got a 1.6GTD block with melted pistons but n/a pistons are probably of a different alloy also, but it will take a turbo no problem. Fuel it a bit, just dont keep the fuel on when it starts to smoke.
regards, DM
Reply #9September 02, 2005, 02:21:17 pm
« Reply #9 on: September 02, 2005, 02:21:17 pm »
how much do you want for a K03????????
Reply #10September 04, 2005, 09:36:18 am
DieselMonkey
  • 124
« Reply #10 on: September 04, 2005, 09:36:18 am »
I sent you a PM
DM
Reply #11September 04, 2005, 02:24:02 pm
« Reply #11 on: September 04, 2005, 02:24:02 pm »
thanks!!  and btw, if you're going to turbo an N/A be sure to get an oil cooler.   either liquid to liquid or air/liquid type should be good
Reply #12September 10, 2005, 12:44:31 am
carrizog60
  • 978
« Reply #12 on: September 10, 2005, 12:44:31 am »
i have a 1.6gtd but is mess...
i can arrange a 1.6D is good shape.are the oil squirters the only difference?can i swap the oil squirters to the 1.6D. my turbo is a KKK24 :?:
Portugal
