General Information
Troubleshooting
alternator squealing
Topic: alternator squealing (Read 5941 times)
April 17, 2009, 08:35:48 pm
jettabrendan
geschwindigkeitsueberschreitung
April 17, 2009, 08:35:48 pm »
new belt, new alternator, same old irritating and embarrassing shreaking sound coming from under the hood. When i put a load on the alternator like a/c or even heat it starts. worse when its wet. Besides the hard to find splash guard, what other alternatives does one have to cover it all up?
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
April 17, 2009, 10:12:07 pm
subsonic
April 17, 2009, 10:12:07 pm »
Which car is it on?
April 17, 2009, 10:32:16 pm
jettabrendan
April 17, 2009, 10:32:16 pm »
1991 and 92 td's
April 17, 2009, 11:49:59 pm
April 17, 2009, 11:49:59 pm »
What amp alt's? 65 or 90?
April 18, 2009, 03:12:29 am
Patrick
April 18, 2009, 03:12:29 am »
V belt is slipping on the alternator, I get it on a regular basis. You can try taking some sandpaper or emery cloth to the pulley (with the alternator out of the car). Pulley should come off the alternator in two pieces....... Too much wear, probably should have a new pulley.
April 18, 2009, 03:16:56 am
Smokey Eddy
April 18, 2009, 03:16:56 am »
Has anyone roughed up the pulley with emery cloth and not shredded the belt?
ps. is this in the correct section...
Ed
THROWN ROD
April 18, 2009, 06:42:29 am
April 18, 2009, 06:42:29 am »
Quote from: "Smokey Eddy"
It is now.
April 18, 2009, 08:49:43 am
April 18, 2009, 08:49:43 am »
are you sure the belt has enough tension? i just replaced the belt and it was a tad bit smaller and it fits on real tight like. My car used to squeal ALL the time dry or wet
it was embarrasing
April 18, 2009, 10:34:00 am
jettabrendan
April 18, 2009, 10:34:00 am »
Yeah the belt is tight it squeals even when I first start it and even if its bone dry.
April 18, 2009, 10:35:50 am
jettabrendan
April 18, 2009, 10:35:50 am »
I have air so it should be a 90 amp
April 18, 2009, 01:51:57 pm
Smokey Eddy
April 18, 2009, 01:51:57 pm »
Mine is starting to squeal to! I just replaced it last week!!!
I think it's just loose. Belts stretch over time.
Is your belt all smooth and shiny?
Ed
THROWN ROD
Reply #11
April 18, 2009, 03:13:18 pm
jettabrendan
Reply #11 on:
April 18, 2009, 03:13:18 pm »
Nope its brand new same as the alternator
Reply #12
April 18, 2009, 05:18:42 pm
Reply #12 on:
April 18, 2009, 05:18:42 pm »
http://www.vwdieselparts.com/forum/viewtopic.php?t=8173&highlight=belt+tensioner
check out that link...I am doing that with my new turbo engine as soon as it is in. I started it already with the N/A. I replaced the bearing, retightened, sanded, etc and the thing would never stop squeeling. I had everything off the front of the engine put it all back on after inspecting and cleaning and it still did it....right now I have a metal piece with 2 small roller bearings on one end and a hole in the other just like the guy above. I think I even posted in that thread a couple of times when I started to make that piece.
Round 2
Reply #13
April 26, 2009, 04:41:17 pm
jettabrendan
Reply #13 on:
April 26, 2009, 04:41:17 pm »
i wonder if getting a new alt pulley will solve it?
Reply #14
April 26, 2009, 06:09:55 pm
Reply #14 on:
April 26, 2009, 06:09:55 pm »
but you already got one when you got a new alt no? or did u have to use your old one?
General Information
Troubleshooting
