Author Topic: T2 comparison & performance  (Read 6708 times)
April 14, 2009, 03:17:25 pm
blackdogvan
  • 574
« on: April 14, 2009, 03:17:25 pm »
I searched with little luck beyond a few comparisons to a K14.
What can a T2 handle boost wise & where would you rate it in the turbo hall of fame. Ideally I'm looking for a GT15 for this build but am having trouble. I'd like 15-18lbs & low RPM spool.
Some are water cooled while some aren't which makes it more "fun"...
1991 Vanagon 1.9 mTDI
Reply #1April 15, 2009, 10:06:20 am
blackdogvan
  • 574
« Reply #1 on: April 15, 2009, 10:06:20 am »
bump... no one has some comments on T2 performance??
Reply #2April 15, 2009, 02:17:50 pm
AdAm84
« Reply #2 on: April 15, 2009, 02:17:50 pm »
I guess not. Nobody seems to have any info on Chrysler T-3's either. oh well. A GT17 may be easier to find than the 15. Just an idea, but I would check the Comp maps first. Good Luck with your search.
Reply #3April 15, 2009, 02:27:14 pm
blackdogvan
  • 574
« Reply #3 on: April 15, 2009, 02:27:14 pm »
Well the thing is I found T2 for sale. I've heard from one good source that it should be a good 20psi turbo but am looking for some more opinions...
Reply #4April 15, 2009, 09:45:58 pm
« Reply #4 on: April 15, 2009, 09:45:58 pm »
I don't think it's a 20psi turbo but do you really need 20psi?
Get a good FMIC and run 15. I was thinking about upgrading my gassers k03 to a larger unit but the loss of bottom end doesn't appeal to me at all. I'm going to get a good FMIC to replace the side mount and I think I'll be happy.
Reply #5April 16, 2009, 03:49:53 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #5 on: April 16, 2009, 03:49:53 am »
after driving around with a t3 and actually being able to see all the time it's making 0psi... i would trade it for a k14 any day i think.
Sure it'll go really high but ... it's just not practical at all. I'd much prefer a smaller turbo that maxes at 20 but will get to 10 with way less fueling and rpm.
Ed
Reply #6April 16, 2009, 09:01:56 am
blackdogvan
  • 574
« Reply #6 on: April 16, 2009, 09:01:56 am »
No I dont think I need 20 but want to have a turbo with the internals that can. FMIC isn't really an option on the van, I have a medium all aluminum Saab unit tucked into the air intake same as luckyp. Well I think I'll try out this T2, I'll post my results.
Reply #7April 16, 2009, 10:59:32 am
« Reply #7 on: April 16, 2009, 10:59:32 am »
I forgot you had a van.
Your SAAB IC should be fine. I think you will be happy with the t2.
Reply #8April 16, 2009, 12:07:58 pm
blackdogvan
  • 574
« Reply #8 on: April 16, 2009, 12:07:58 pm »
Ya I think so too. I did find this page with some interesting info.
http://www.ruralnet.net.au/~johnh/garrett2.htm
Similar to the T15 with the GT series being the next generation. Not the proper curves but a good comparison to the T25. Its exactly what I wanted to see.
Reply #9April 16, 2009, 03:09:27 pm
foxracer1
  • Authorized Vendor
  • 991
« Reply #9 on: April 16, 2009, 03:09:27 pm »
I love my T3
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #10April 17, 2009, 09:18:56 am
idgtd
  • 86
« Reply #10 on: April 17, 2009, 09:18:56 am »
Quote from: "foxracer1"
I love my T3
Damn right. My T3 seems to work pretty good. It doesn't make much boost on the highway (~2psi), but then again it doesn't really need to. Of course, I put a 2.25" mandrel bend exhaust on when I turbocharged the car, so with the factory peashooter it might not work as well.
Stephen Phillips
1981 VW Rabbit Diesel (mit turbolader)
1985 VW Scirocco Wolfsburg Ed.
1970 Porsche 911T
1972 MG Midget
1996 Chevy C3500 Dually
1930 Model A Ford
Reply #11April 18, 2009, 12:15:59 pm
nokivasara
  • 115
« Reply #11 on: April 18, 2009, 12:15:59 pm »
I had a T2 in a Passat and it spools really fast  :shock:
I could easily make boost in first gear on the parking lot, try that with a T3.
I had it up to 1.2 Bar with no issues but I think that's a bit on the high side for it, probably a lot of back pressure @1.2
1 Bar should be fine, that's about 14psi I think.
Caddy 1.6N/A pushing 400 000km and going strong!
