Author Topic: Converting gas body over to diesel  (Read 11582 times)
August 30, 2005, 03:36:23 am
Rat407
  • Authorized Vendor
  • 289
« on: August 30, 2005, 03:36:23 am »
I was wondering how hard it would be to put a 1.6 TD into a gas body rabbit, Golf, or Jetta?  Is it worth it and is it hard to do?  I can find gas body vehicles all day long but no diesels.
Thanks
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta  ECO TD
Reply #1August 30, 2005, 08:10:06 am
BlackTieTD
  • 1512
« Reply #1 on: August 30, 2005, 08:10:06 am »
not too difficult, but of course it would be better to start with a diesel body.
i'd disconnect the fuel return at the tank, and run the car until bone dry and it stalls out. i'd probably fill the tank 1/2 full with diesel or something and then pop the hose off the bottom of the tank, drain out that gas-fouled diesel (or have the tank properly flushed, but if you need to remove the tank, the rear beam has to be dropped).
you'd have to get rid of the CIS fuel pump from under the car and just fill the gap with fuel line. you'll need to run fuel line to where you need it from the fuel line feed and return at the firewall, passenger side.
i'd probably pick up a diesel gauge cluster meant for your car, that plugs into the wiring harness you have for the engine you are installing. ideally i'd get the fusebox, wiring, gauges, engine, all from the same donor. make sure you get the wiring and fuse holder for the glow plugs as well. the advance knob and cable wouldn't be a bad thing to get from the donor either.
there's probably more but that will get it running..
Reply #2August 30, 2005, 01:04:23 pm
Rat407
  • Authorized Vendor
  • 289
« Reply #2 on: August 30, 2005, 01:04:23 pm »
Thanks,  That is a start and some things I didn't think about untill you mentioned them.
1991 Jetta  ECO TD
Reply #3August 30, 2005, 05:40:36 pm
Master ACiD
  • 328
« Reply #3 on: August 30, 2005, 05:40:36 pm »
is there any way to fit a vw truck diesel tank under a gasser rabbit to replace the gas tank and lines?
Reply #4August 30, 2005, 06:53:24 pm
vwmike
  • Authorized Vendor
  • 1158
« Reply #4 on: August 30, 2005, 06:53:24 pm »
Quote from: "Master ACiD"
I think that's gonna be a no.
Reply #5August 30, 2005, 07:22:10 pm
Master ACiD
  • 328
« Reply #5 on: August 30, 2005, 07:22:10 pm »
well maybe it will fit in the trunk?
Reply #6August 30, 2005, 08:00:27 pm
vwmike
  • Authorized Vendor
  • 1158
« Reply #6 on: August 30, 2005, 08:00:27 pm »
Maybe, but why? There is no reason you can't use the gasser tank.
Reply #7August 30, 2005, 10:24:16 pm
Master ACiD
  • 328
« Reply #7 on: August 30, 2005, 10:24:16 pm »
im having bad thoughts about the gasser sending unit and seals not being compatible with diesel. espically the fuel filler etc.
i once dripped a bit of diesel on some gas line and it swelled up to twice its size and got all soft. i would hate to see that happen with rubber gastank parts?
Reply #8August 30, 2005, 10:29:50 pm
  • 2931
gas to diesel
« Reply #8 on: August 30, 2005, 10:29:50 pm »
Yep the fuel tank is the same. Gas or diesel.
 The filler hole on a gas car won't fit the diesel nozzle at the station but the restriction can be removed pretty easily.
 I can't picture a caddy tank fitting under a Rabbit very well.
Reply #9August 30, 2005, 10:32:17 pm
  • 2931
radiators
« Reply #9 on: August 30, 2005, 10:32:17 pm »
I think the A2 radiators are different so if you are swapping it into an A2  gas Jetta you'll have to grab the right radiator.
Reply #10September 03, 2005, 03:13:54 pm
fillmore
  • 60
    • http://fillmorenorthband.tripod.com
« Reply #10 on: September 03, 2005, 03:13:54 pm »
hey what about wiring up glow plugs to the ignition? and my diesel has standard steering but the gas body im using was equiped with power steering so if i didnt change the rack would it just be like drivivng a standard steering car cause its not hooked up to a pump or would it be like having no power steering belt and almost impossible to steer, i think ive got everything else covered for my transition just these things need to be addressed
Reply #11September 04, 2005, 02:46:53 pm
Master ACiD
  • 328
« Reply #11 on: September 04, 2005, 02:46:53 pm »
i just won this car on ebay
 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=7996477336&sspagename=STRK%3AMEWN%3AIT
i talked to the seller and the car has a nearly rust and dent free body. i plan to swap all the diesel related parts into this car and run some homemade biodiesel.
Reply #12September 07, 2005, 08:49:20 am
zyewdall
  • 393
« Reply #12 on: September 07, 2005, 08:49:20 am »
I'm currently putting a 1.6NA in a 1991 GTI gasser.  So far the diesel's sitting on the garage floor, and the gasser and it's ECU have been ripped out of the GTI.  I'll post pictures in the coming months as I get the diesel put in.
For glow plugs, I'm just going to use a momentary pushbutton switch on the dash.  And for power steering, I'm just disconnecting it -- a rabbit is light enough that it should be okay, and I don't like the feel of power steering on the highway anyway.  I drove my old subaru with the power steering unhooked for a few months and once you got used to it, it was fine.
'84 Mitsubishi 4x4 2.3L turbo biodiesel pickup
'91 VW Rabbit GTI with 1.6 biodiesel transplant
'81 Toyota longbed 2wd 2.2NA biodiesel pickup (for sale)
'89 Subaru 4x4 touring wagon
 '82 subaru 4x4 TDI wagon -- project on hold
1976 Ford Sasquatch pickup
Reply #13September 07, 2005, 08:55:38 am
VWRacer
  • 649
« Reply #13 on: September 07, 2005, 08:55:38 am »
Those are sweet cars, Acid! The 84's are the last year of the Mk1 and have all the evolutionary improvements to that series without all the weight of the Mk2.
Stan
C-Sports Racer
Reply #14September 07, 2005, 09:27:51 am
BlackTieTD
  • 1512
« Reply #14 on: September 07, 2005, 09:27:51 am »
don't want to go too far off topic here (maybe you can PM me..) but what evolutionary improvements are you refering to? there was an evolution of the mkI, but i don't know if i'd tie the word 'improvements' in with that. just curious.  :)
