Author Topic: Brake upgrade tips?  (Read 13645 times)
Reply #15December 06, 2012, 07:49:49 pm
CrazyAndy
  • 739
Re: Brake upgrade tips?
« Reply #15 on: December 06, 2012, 07:49:49 pm »
I'm pretty sure the mk3 beam is wider than the mk2. Depending on your tires I think it's ok though.
Want to say you're right.  Either way, the MK3 rear spindles will go on the MK2 axle just fine, as will  just the discs. You can use a 16V Scirocco MC for 9.4", or the Corrado MC if you go 10.1" fronts.  The reason is mostly to prevent the rear discs from locking up due to the amount of fluid the stock MC's drum circuit pushes.
Reply #16December 08, 2012, 12:47:47 pm
JBG3
  • 227
« Reply #16 on: December 08, 2012, 12:47:47 pm »
ive been to the yard today and ive found a 97 Jetta GT with rear discs on it.  (the only mk3 in the yard that doesn't have drums).
I will have to return on monday morning with a spade so I can dig down enough to remove relevant brake stuff.  Im assuming I can use this 97 stuff on my 86 without too much difficulty.
Question, are the spindles between the caliper and drum identical apart from the provision for caliper bolt holes?  Does anyone sell these stub axles new?  I have searched and only found the drum type stub axles
EDIT-  Autohausaz has the caliper specific stub axles for around 60 bucks apiece.  Might go this route rather than dig up some rusted POS stub axle instead.
« Last Edit: December 08, 2012, 01:59:34 pm by JBG3 »
1986 1.6NA Jetta
Reply #17December 09, 2012, 03:09:22 pm
« Reply #17 on: December 09, 2012, 03:09:22 pm »
Tyler, have you added this to the FAQ thread or no? some good info.
How much of an upgrade are you looking for? And what kind of upgrade are you looking for? Are you hill racing this thing? Driving like a dickhead and need more "OH %&#*#*" stopping power?
I might be one to think too big of a brake might be a very bad thing, in some ways. Much less weight so they will lock up a whole lot easier.
A good vented 9.4" setup will stop a turned up AAZ with rear drums quite adequately. I see that you've got an 85 GOLF, have you motor swapped? Is it still non-turbo? 9.4" solids will do more than fine for that car.
I daily an 84 Jetta (2150lbs with me in it) that has a more than stock powered AHU engine, it has 9.4 solid rotors up front and 180x30 drums in the back. It stops more than adequately.
Not trying to rain on the parade man, I am just giving you some real world experience.
Reply #18December 09, 2012, 03:12:25 pm
« Reply #18 on: December 09, 2012, 03:12:25 pm »
I have not added it to the FAQ, go ahead.
Another situation where larger/vented brakes would help is if you do a lot of mountain driving, or if you tow. Also if you drive on the 401 ::)
Reply #19December 09, 2012, 05:07:06 pm
« Reply #19 on: December 09, 2012, 05:07:06 pm »
Alright I will.
I would go vented first, and then maybe the next time it needs brakes.. upgrade to a bigger size.
Reply #20December 09, 2012, 08:02:40 pm
« Reply #20 on: December 09, 2012, 08:02:40 pm »
mk3 is MUCH wider...
4" wider than the mk2 rear end..
i dont see it possible to swap a mk3 rear beam into a mk2, and still run tires, without hitting your fenders..
Reply #21December 10, 2012, 08:40:55 am
JBG3
  • 227
« Reply #21 on: December 10, 2012, 08:40:55 am »
for me personally, its twofold, one lots of crowded freeway driving.  (another upgrade im considering is a pair of additional brake lights on the rear deck.  You get rear ended once, you get shy, and after all, the mk2 is still a slow beer can compared to most other vehicles on the road)
2nd, i find calipers cleaner and easier to service/inspect, I hate dealing with rusted out drums full of brake dust.
1986 1.6NA Jetta
