Author Topic: Boost Buzz??  (Read 4153 times)
April 06, 2009, 07:34:53 am
ein bora
  • 377
Boost Buzz??
« on: April 06, 2009, 07:34:53 am »
So I installed a set of isspro gauges which includes a mechanical boost gauge. Upon acceleration I'm hearing a buzzing type of noise coming from the gauge?? It's only there when accelerating and stops when decelerating?? I also thought it could be a vibration with the boost line/hose - any ideas what it might be. Gets annoying.
If you can't take advice - then you can't be helped!
Reply #1April 06, 2009, 09:26:35 am
Boost Buzz??
« Reply #1 on: April 06, 2009, 09:26:35 am »
Yup, there will be some oscillations in boost pressure that cause many needles to "buzz"... several vendors (Draft42 for example) sell a boost hose T with a restriction specifically to damp this annoying noise.  I have one... works great.
If you can't find one locally Concept 1 in Calgary has 'em... 3/4s of the way down this page:
http://www.concept1.ca/engine%20gauges.htm
It's their part number 42D 42-003 .
Reply #2April 06, 2009, 12:08:34 pm
ein bora
  • 377
Boost Buzz??
« Reply #2 on: April 06, 2009, 12:08:34 pm »
Quote from: "Vincent Waldon"
Thanks for the info! much appreciated.
Reply #3April 06, 2009, 12:25:24 pm
smutts
  • 720
    ClackClackClackClackClack
Boost Buzz??
« Reply #3 on: April 06, 2009, 12:25:24 pm »
Or stuff some cigarette filter cotton into the pipe until it shuts up. The buzz is the guage trying to respond to the 30 odd sucks a second as the engine cylinders each breathe. The gears in the guage will wear out fast too.
Reply #4April 06, 2009, 02:27:03 pm
ein bora
  • 377
Boost Buzz??
« Reply #4 on: April 06, 2009, 02:27:03 pm »
Quote from: "smutts"
Pipe - what pipe??
Reply #5April 06, 2009, 06:49:44 pm
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
Boost Buzz??
« Reply #5 on: April 06, 2009, 06:49:44 pm »
Someone else posted a fix where he gently melted the plastic tee branch going to the gauge & then put a tiny hole in the melted end, thereby making a cheap restrictor.  I'm not claiming credit for the idea - just can't remember where I read it.
I've been using a clothespin on my rubber line until I get around to either buying a restrictor tee or doing the melt mod...  It's really shade tree, but it does stop the buzz.  Maybe I should just paint the clothespin black & chrome the spring... :shock: (only kidding)
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #6April 14, 2009, 12:44:29 pm
smutts
  • 720
Boost Buzz??
« Reply #6 on: April 14, 2009, 12:44:29 pm »
Pipe - what pipe??
The one from your new guage to wherever it taps into the boost plumbing. :wink:
Reply #7April 14, 2009, 02:40:33 pm
Jettage1
  • 202
Boost Buzz??
« Reply #7 on: April 14, 2009, 02:40:33 pm »
Reporting back... I did the "melted tee" mod.  It does work and is very easy.  It doesn't take much of a hole, though.  I used a pin, and only pushed it in maybe 1/16".  Have just the faintest buzz now - not really annoying.
Steve
92 Jetta EcoDiesel
Reply #8April 16, 2009, 07:34:47 pm
ein bora
  • 377
Boost Buzz??
« Reply #8 on: April 16, 2009, 07:34:47 pm »
Quote from: "Jettage1"
Ya - I tried it too, but maybe my hole is still to large as it's better but not were you are with your's.  I'll try again. Thanks for the update.
