Weird pulsing problem
Topic: Weird pulsing problem (Read 3037 times)
April 04, 2009, 06:08:23 am
silvertdi
April 04, 2009, 06:08:23 am »
My 1.6 NA is doing something weird at 55 mph. At precisely 55 mph the engine starts to "pulse" or "shudder" rapidly. I can tell its the engine because its been "pulling" funny. It seems like it has a 2-stroke power band where it will pull then fall on its face. Once I get up to 55 the engine shudders. It has new tires and alignment and overall is as smooth as glass. Any suggestions? Thanks.
April 04, 2009, 06:25:21 am
hamradio
April 04, 2009, 06:25:21 am »
What gear is this in?
April 04, 2009, 06:57:48 am
April 04, 2009, 06:57:48 am »
did it happen after you added the new tires? Maybe they are out of balance?
April 04, 2009, 02:25:28 pm
LoneWolf
April 04, 2009, 02:25:28 pm »
like a juddering through the pedal at certain revs?
April 04, 2009, 02:39:20 pm
silvertdi
April 04, 2009, 02:39:20 pm »
Quote from: "LoneWolf"
Yes, like a juddering in the pedal at a certain rev. The whole car shakes. I can tell the engine is shaking in its mounts.
It's in 4th gear. The tires aren't out of balance. This feels way different.
April 04, 2009, 07:23:00 pm
maxfax
April 04, 2009, 07:23:00 pm »
Would it feel anything similar to a gasser with bad plug wires?
April 05, 2009, 05:31:21 am
silvertdi
April 05, 2009, 05:31:21 am »
Yeah, like a gasser with a cylinder down but only at a certain RPM.
April 05, 2009, 06:00:09 am
clbanman
Cambridge, Ontario
April 05, 2009, 06:00:09 am »
Does it do it in 3rd gear at the same rpm? If it's engine related it should. If it's actually only speed related it's something between 4th gear in your trans and where the rubber meets the road.
Calvin
91 VW Golf 1.6NA 5spd
April 05, 2009, 05:15:56 pm
Jettage1
Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
April 05, 2009, 05:15:56 pm »
Make sure your IP bolts are all present & accounted for, and all are tight.
Steve
92 Jetta EcoDiesel
pumped by Giles...powered by Frybrid...functional by dumb luck
April 05, 2009, 05:35:27 pm
April 05, 2009, 05:35:27 pm »
The one at the bottom of the pump just below the injector lines can cause some REALLY weird behavior when it's missing. My car didn't have one there when I got it and it would do some totally nutbar surging at certain RPM ranges.
Just got back from a road trip and that bolt had come loose on me - started noticing a vibration that wasn't there before. Once I fixed it the motor was smooth as butter.
