Author Topic: Weird pulsing problem  (Read 3040 times)
April 04, 2009, 06:08:23 am
silvertdi
  • 125
« on: April 04, 2009, 06:08:23 am »
My 1.6 NA is doing something weird at 55 mph.  At precisely 55 mph the engine starts to "pulse" or "shudder" rapidly.  I can tell its the engine because its been "pulling" funny.  It seems like it has a 2-stroke power band where it will pull then fall on its face.  Once I get up to 55 the engine shudders.  It has new tires and alignment and overall is as smooth as glass.  Any suggestions?  Thanks.
Reply #1April 04, 2009, 06:25:21 am
hamradio
  • 282
« Reply #1 on: April 04, 2009, 06:25:21 am »
What gear is this in?
Reply #2April 04, 2009, 06:57:48 am
« Reply #2 on: April 04, 2009, 06:57:48 am »
did it happen after you added the new tires? Maybe they are out of balance?
Reply #3April 04, 2009, 02:25:28 pm
LoneWolf
« Reply #3 on: April 04, 2009, 02:25:28 pm »
like a juddering through the pedal at certain revs?
Reply #4April 04, 2009, 02:39:20 pm
silvertdi
  • 125
« Reply #4 on: April 04, 2009, 02:39:20 pm »
Quote from: "LoneWolf"
Yes, like a juddering in the pedal at a certain rev.  The whole car shakes.  I can tell the engine is shaking in its mounts.
It's in 4th gear.  The tires aren't out of balance.  This feels way different.
Reply #5April 04, 2009, 07:23:00 pm
maxfax
  • 2126
« Reply #5 on: April 04, 2009, 07:23:00 pm »
Would it feel anything similar to a gasser with bad plug wires????
Reply #6April 05, 2009, 05:31:21 am
silvertdi
  • 125
« Reply #6 on: April 05, 2009, 05:31:21 am »
Yeah, like a gasser with a cylinder down but only at a certain RPM.
Reply #7April 05, 2009, 06:00:09 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #7 on: April 05, 2009, 06:00:09 am »
Does it do it in 3rd gear at the same rpm?   If it's engine related it should.  If it's actually only speed related it's something between 4th gear in your trans and where the rubber meets the road.
Calvin
91 VW Golf 1.6NA 5spd
Reply #8April 05, 2009, 05:15:56 pm
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
« Reply #8 on: April 05, 2009, 05:15:56 pm »
Make sure your IP bolts are all present & accounted for, and all are tight.
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #9April 05, 2009, 05:35:27 pm
« Reply #9 on: April 05, 2009, 05:35:27 pm »
The one at the bottom of the pump just below the injector lines can cause some REALLY weird behavior when it's missing.  My car didn't have one there when I got it and it would do some totally nutbar surging at certain RPM ranges.
Just got back from a road trip and that bolt had come loose on me - started noticing a vibration that wasn't there before.  Once I fixed it the motor was smooth as butter.
