Author Topic: FS: COMPLETE overbored 1z/AHU Shortblock and much much MORE!  (Read 16589 times)
March 22, 2009, 01:08:14 pm
RabbitGTDguy
  • 1274
« on: March 22, 2009, 01:08:14 pm »
Ok, so no more feeler thread. This is the real deal. Finally got a chance to get everything out, take pictures, etc. etc. of all the stuff that I had for the b3 mTDI build including the complete shortblock that I had built for it.  I also have a variety of other bits around too.
First...the shortblock.  Don't ask me to part it. If you'd like to add accessories/brackets to it, etc. That is fine...and cost will be reduced vs. buying the accessories individually.  However, I will NOT part the shortblock from its current status at all. Lowballers...don't even PM/email or ask me.  Its just not going to happen.
Now, for the shortblock.
Started out with a motor with 200k plus on it.  Motor was in good shape but very tired as you can imagine.  I did EVERYTHING on the shortblock to bring it back into factory spec and to this point it includes everything listed below
-block was stripped, degreased and acid dipped at local engine machine shop.
-Block professional overbored and honed
-block sandblasted by myself, primed (x2) and painted (x3) with ceramic based engine paint
-crank polished
-all rods checked and resized
-Pistons are 1st OS units, OEM, ALH style units with Goetze rings
-All bearings are OE to include main bearings with NON-intergrated 6 pc thrust bearing(I never build motors with the intergrated style) and OE rod bearings (all in standard...were well within spec).
-Installed new intermediate shaft bearings
-all hardware replaced with OEM parts (rod bolts, main bearing bolts)
-All seals replaced with OEM units
-New crankshaft sprocket bolt of course...
-New oil pan
-ADDED new windage tray with integrated oil pan seal
This will make someone a super nice motor and/or a shortblock to work with.  I didn't finish making it a complete longblock for a few reasons...namely the fact that I will not recoup my labor and time into the motor by doing so and much of the interest I have received thus far has been for the shortblock complete only as many like to go their own route for doing the head...or already had one.  However, if someone wanted a complete longblock and wanted to buy everything and wanted to pay a bit extra for me to finish it, I could do that. For now...
$1250.00 on the shortblock itself...as pictured. Deposit taken on complete shortblock.  Sale pending completed payment
I also have a good/used head from the same motor. Complete as it sits here. $300.00
Next up...the CTN 02j/a 5 speed trans I had for the b3 mTDI swap. In great condition. NO issues, no grinds! about 120k on it. Complete as it sits... $450
VR6 clutch kit (less than 2k on the kit) that I'll throw in for free if you pay my asking price. SOLD
Starter for 5 speed 02j style tranny (not like 02a tranny starters...has different nose...02a unit WILL NOT work in the b4/mk3 TDI trans). This is a practical new REMAN unit. $125.00
Have a few single mass 02a style flywheels around as well...will consider selling one if someone is in need...
Next...my little secret for the b3 mTDI swap. A nice Holset HX25w turbo that I was going to use on it.  A quick spooling 6cm hot side with a compressor side that is larger than my 50trim 300D unit and also the holset flows quite a bit better (and more efficiently) than a T3...look at their site for specs on the HX25. he inlet flange is a T25 style flange (will need adaptor for most manifolds out there...unless you find a t25 flanged 8v manifold by some stroke of luck) and as a V-band setup for the hot side (though could be removed for a more standard style flange) $250.00 SOLD
This will make for a nice little monster on a TDI motor...without sacrificing much at all in spooling or economy...I'm going with something slightly larger but similar as the new turbo on the mk1 mTDI.
Speaking of turbos...how about a few exhaust manifolds.
First is  ATP style 8v T3 flanged (backset) exhaust manifold. This is what I run on my Mk1 mTDI and had gotten one for the b3 swap as well. Of course...not using it now.  I don't believe it has EVER been used at all. In perfect shape. $150 SOLD
The stock IDI TD manifold is in good shape too. Could use a good blasting... 50.00 SOLD
In doing this build, I also took the time and sandblasted ALL accessories, primed and painted each one...they are below here
Injection pump bracket for 1z/AHU  $60.00 SOLD
Pulleys to include...
Cranshaft pulley 50.00 (will not go until shortblock is sold...buyer gets them if they want/need it)
Intermediate shaft pulley (same as above...shortblock option first)
Power Steering pulley 15.00
Camshaft sprocket 25.00
Injection pump pulley (keyway cut for 4bt pump for mTDI) 40.00
Injector hold downs (will go with complete head)
Upper timing belt backing plate (mounts to block, head, and IP bracket) $25.00 SOLD
Also have the lower t belt cover as well as the upper cover (neither are pictured)
Alternator w/ AC accessory bracket assembly for 1z/AHU... $85.00 SOLD
blasted/primed/painted valve cover for 1z/AHU $40.00
1z/AHU injector lines $50.00
TDI intake manifold (sandblasted...) $50.00 SOLD
Nearly new 1z/AHU elephant hose (block to puck on head) $20.00 SOLD
1z/AHU (among others with 8v) water pump with housing (less than 2k) $30.00
ALL NEW
Conti Timing belt  $25.00 shipped SOLD
Conti Acc belt (serp) $15.00 shipped SOLD
Conti v-belt 10.00 shipped SOLD
OEM timing belt tensioner 38.00 shipped SOLD
All belts/tensioners are for the MK3 or B4 1z/AHU motors...will fit BOTH models as long as they have A/C
How about a New COMPLETE Reinz cylinder head rebuild kit? Includes cam seal, valve stem seals, valve cover gasket, vc grommets, water flange o-rings, exhaust manifold gaskets, intake manifold gasket, etc. I'll throw in new OEM intake manifold bolts as well... $70.00 shipped SOLD
2 notch OEM Reinz head gasket $35.00 shipped
Other misc bits...
Complete G60 intercooler setup with piping $50.00
Audi 5k intercooler in near perfect condition, with mounting bracket... $50.00
Phew...think that is it. All prices are less shipping unless shipping is noted.  I ship via USPS or UPS in most cases...preferably USPS if possible. Shipping for items is calculated for the lower 48...not CAN or outlying areas.  Shipping charged will only be actual shipping.
I am willing to ship the larger bits...even the block, trans, etc. but buyer pays shipping of course. As always, local pickup is possible and meeting within a reasonable distance from 14905, NY is possible too.
As for the TDI bits. There is everything here minus maybe a few nuts and bolt...and head bolts for that matter (had studs...but they are already gone) to make a COMPLETE motor.  Currently, the motor could go the mTDI route or it could still be a eTDI setup.
That said, with the TDI stuff and all the new parts, etc. I could consider making a deal for someone who wanted everything and had a figure in mind. Or a combination of items.  So, its up to you. Here it is...let the fun begin. You can reach me here through PM or email [email protected]
Joe[/b]
1972 VW Westfalia
2001 Audi TT 225 Quattro Roadster (something newer :) )
Reply #1March 22, 2009, 01:38:54 pm
RabbitGTDguy
  • 1274
« Reply #1 on: March 22, 2009, 01:38:54 pm »
Forgot to mention...I also have the following items for those wanting to go the route of mTDI in a b3, or a corrado.
I have a main engine wiring harness from a B3 AAZ car... $45.00
Also, kilo cluster from AAZ b3 (will work in a 'rado), everything works... $50.00
B3 AAZ (will fit others) Airbox and turbo inlet hose (box to turbo) $30.00
Joe
1972 VW Westfalia
Reply #2March 25, 2009, 01:22:31 pm
RabbitGTDguy
  • 1274
« Reply #2 on: March 25, 2009, 01:22:31 pm »
All PM's replied to...sale pending on intake manifold...
Joe
1972 VW Westfalia
Reply #3March 26, 2009, 12:48:29 pm
RabbitGTDguy
  • 1274
« Reply #3 on: March 26, 2009, 12:48:29 pm »
As of this morning the following items are SOLD
IDI TD exhaust manifold
1z/AHU timing belt backing plate (upper)
1z/AHU accessory bracket
1z/AHU IP bracket
Joe
1972 VW Westfalia
Reply #4April 01, 2009, 04:10:39 am
RabbitGTDguy
  • 1274
« Reply #4 on: April 01, 2009, 04:10:39 am »
Holset is SOLD and on its way to the UK.
Joe
1972 VW Westfalia
Reply #5April 11, 2009, 04:24:40 am
RabbitGTDguy
  • 1274
« Reply #5 on: April 11, 2009, 04:24:40 am »
Deposit taken on complete shortblock so SALE PENDING
Intake manifold is SOLD
T3 ATP Exhaust manifold is SOLD
Head, tranny and other bits are still available with exception of valve cover.
Joe
1972 VW Westfalia
Reply #6April 16, 2009, 06:36:01 pm
RabbitGTDguy
  • 1274
« Reply #6 on: April 16, 2009, 06:36:01 pm »
Following items are SOLD as of today.
-VR6 clutch
-Conti Timing belt
-Timing Belt Tensioner
-Conti accessory belt
-Conti v-belt for power steering
-Victor Reinz Complete head rebuild set (still have head gasket)
-2nd elephant hose
1972 VW Westfalia
Reply #7August 28, 2009, 04:01:07 pm
RabbitGTDguy
  • 1274
Re: FS: COMPLETE overbored 1z/AHU Shortblock and much much MORE!
« Reply #7 on: August 28, 2009, 04:01:07 pm »
OK, so....I'm finally having to do this. Initially I've had a deposit on the shortblock here, but its been several months now and I still have the shortblock here and no full payment; so regrettably, I need to move this out of my garage (I need the room, especially in preparation for winter). With that, I'm putting the complete shortblock back up for sale. I have time and cash tied up on this that I'd like to bring back into focus. I've had many inquires since I took the deposit, I apologize to those especially who offered full payment, on the spot...but here is your chance again.
That said...the complete shortblock is back up for sale. I'm firm on the price...well worth it and then some actually.
$1250.00
Additionally, I have the pulleys that I've refinished (blasted, painted, etc.) and the valve cover as well that I'd include for 50.00 extra. I had them priced individually, but they'll go for that to someone who wants the motor. Most of the other items are gone, I'll update the front post here to make sure its completely up to date.
Hoping to move this out before the first week of September. I had offered to driving within a few hours of Elmira, NY 14905 to help with shipment/transport of this...but my time is growing short as a new school year is approaching and I still have a lot of preparations to do in my classroom.
Serious inquires only...thanks! You can email me directly at [email protected] if you want to avoid a possible time delay through PM's via TDIClub here.
Joe
1972 VW Westfalia
Reply #8September 07, 2009, 07:25:11 am
RabbitGTDguy
  • 1274
« Reply #8 on: September 07, 2009, 07:25:11 am »
PM's and emails responded too...but nothing serious. Still here.
Thinking I'm going to put it up on Ebay in the next few weeks.
Joe
1972 VW Westfalia
Reply #9September 10, 2009, 05:36:44 pm
the_mad_rabbit
  • 6
« Reply #9 on: September 10, 2009, 05:36:44 pm »
Cluster sold to me!!! :D - let me know when you ship it out- you have paypal! Need this ASAP! Hate not having a working cluster :(
-AJ
"Life is like a bad margarita with good tequila, I thought as I poured whiskey onto my granola and faced a new day"
Lurker
Reply #10September 20, 2009, 11:52:21 am
myke_w
  • 1099
« Reply #10 on: September 20, 2009, 11:52:21 am »
I'm interested in the head possibly... got a good shipped price for me?
my zip is 45701. Let me know :)
Reply #11September 22, 2009, 02:47:30 pm
RabbitGTDguy
  • 1274
« Reply #11 on: September 22, 2009, 02:47:30 pm »
Once again. Head is sold guys...sold a while back.
AAZ cluster is sold.
Shortblock is heading to ebay in two weeks if I don't have a commited buyer. Tired I messing around with quotes, lowballing, etc.
Joe
1972 VW Westfalia
Reply #12October 24, 2009, 05:52:50 am
RabbitGTDguy
  • 1274
« Reply #12 on: October 24, 2009, 05:52:50 am »
Last chance on the shortblock for anyone interested...and a lot of interest, did about 5 shipping quotes but have never had the follow through. Going to put it on Ebay this weekend. Had it long enough and really could use the cash for another project and the space.
Joe
1972 VW Westfalia
Reply #13October 27, 2009, 06:12:57 pm
RabbitGTDguy
  • 1274
1972 VW Westfalia
Reply #14November 10, 2009, 06:52:27 pm
RabbitGTDguy
  • 1274
« Reply #14 on: November 10, 2009, 06:52:27 pm »
SOLD on Ebay...hoping to see the buyer tomorrow.
1972 VW Westfalia
