Rebuilding AAZ...
Topic: Rebuilding AAZ... (Read 2574 times)
March 18, 2009, 05:37:41 am
CLDiesel
Newbie
Rebuilding AAZ...
March 18, 2009, 05:37:41 am »
I have a motor with 250000km.
What should i be looking to replace when doing a major overhaul?
March 18, 2009, 05:41:41 am
myke_w
Rebuilding AAZ...
March 18, 2009, 05:41:41 am »
likely pistons with rings, all bearings, all gaskets, all seals, head bolts, clutch while it's apart, rod bolts, piston pin bushings
Let me know if you have trouble finding any of it
March 18, 2009, 07:00:42 am
arb
Re: Rebuilding AAZ...
March 18, 2009, 07:00:42 am »
Quote from: "CLDiesel"
The couple IDI's I've had with those miles were still within spec - of course I used 100% synthetic oil, so even the hone marks were still in the bores. Have you done a compression test? That's sill low miles for these engines.
March 18, 2009, 07:04:48 am
myke_w
Rebuilding AAZ...
March 18, 2009, 07:04:48 am »
A bore check is in order for sure
if it's out of spec - you know what you gotta do
March 18, 2009, 11:13:23 pm
CLDiesel
Newbie
Rebuilding AAZ...
March 18, 2009, 11:13:23 pm »
Whats this about the crankshaft pulley kenway? I cant find any recent posts about it...
March 19, 2009, 08:34:38 am
myke_w
Rebuilding AAZ...
March 19, 2009, 08:34:38 am »
The key way wipes out and causes major destruction to the end of the crank.
The fix is to take it off before it happens and machine it to fit a newer style AHU TDI crank pulley.
March 19, 2009, 12:42:15 pm
CLDiesel
Newbie
Rebuilding AAZ...
March 19, 2009, 12:42:15 pm »
Are there any write ups on how to go about doing this?
Rebuilding AAZ...
