Author Topic: Rebuilding AAZ...  (Read 2581 times)
March 18, 2009, 05:37:41 am
CLDiesel
  • 13
Rebuilding AAZ...
« on: March 18, 2009, 05:37:41 am »
I have a motor with 250000km.
What should i be looking to replace when doing a major overhaul?
Reply #1March 18, 2009, 05:41:41 am
myke_w
  • 1099
Rebuilding AAZ...
« Reply #1 on: March 18, 2009, 05:41:41 am »
likely pistons with rings, all bearings, all gaskets, all seals, head bolts, clutch while it's apart, rod bolts, piston pin bushings :)
Let me know if you have trouble finding any of it
Reply #2March 18, 2009, 07:00:42 am
arb
Re: Rebuilding AAZ...
« Reply #2 on: March 18, 2009, 07:00:42 am »
Quote from: "CLDiesel"
The couple IDI's I've had with those miles were still within spec - of course I used 100% synthetic oil, so even the hone marks were still in the bores. Have you done a compression test? That's sill low miles for these engines.
Reply #3March 18, 2009, 07:04:48 am
myke_w
  • 1099
Rebuilding AAZ...
« Reply #3 on: March 18, 2009, 07:04:48 am »
A bore check is in order for sure :) if it's out of spec - you know what you gotta do
Reply #4March 18, 2009, 11:13:23 pm
CLDiesel
  • 13
Rebuilding AAZ...
« Reply #4 on: March 18, 2009, 11:13:23 pm »
Whats this about the crankshaft pulley kenway? I cant find any recent posts about it...
Reply #5March 19, 2009, 08:34:38 am
myke_w
  • 1099
Rebuilding AAZ...
« Reply #5 on: March 19, 2009, 08:34:38 am »
The key way wipes out and causes major destruction to the end of the crank.
The fix is to take it off before it happens and machine it to fit a newer style AHU TDI crank pulley.
Reply #6March 19, 2009, 12:42:15 pm
CLDiesel
  • 13
Rebuilding AAZ...
« Reply #6 on: March 19, 2009, 12:42:15 pm »
Are there any write ups on how to go about doing this?
