Author Topic: Cold start handle  (Read 4154 times)
August 17, 2005, 11:18:01 am
rackley
  • 96
Cold start handle
« on: August 17, 2005, 11:18:01 am »
About 90% of the time when I start with the cold start handle I forget to put it back in once the engine is warmed up.  What negative effects does this have?  Worse mileage?  Lower power?
www.vocontrol.com
VO Control - Programmable VegOil and WVO Controllers
Reply #1August 17, 2005, 11:28:53 am
vwmike
  • 1158
Re: Cold start handle
« Reply #1 on: August 17, 2005, 11:28:53 am »
Quote from: "rackley"
It probably doesn't make much (if any) difference in the mileage, but you might experience the slightest power gain below 2k rpm. Oh, and the engine will be a little bit louder at idle. That's probably about it.
