boost gauge install HELP!!!!!!!!
Topic: boost gauge install HELP!!!!!!!! (Read 4770 times)
February 26, 2009, 07:28:56 pm
L1V3N 1T
Newbie
February 26, 2009, 07:28:56 pm »
hey new to this TD stuff where can i tee in for the boost gauge hose. cant find any lines any where around the engine.
February 26, 2009, 08:16:44 pm
Kantdrivefast
February 26, 2009, 08:16:44 pm »
I tee-ed mine into the line that runs from the turbo to the LDA.
February 27, 2009, 05:55:22 am
nogama3
February 27, 2009, 05:55:22 am »
what car do you have? engine? a few bits of info would help us to help you.
February 27, 2009, 09:17:58 am
L1V3N 1T
Newbie
February 27, 2009, 09:17:58 am »
my bad its a 1990 jetta 1.6TD. that line that you are talking about kantdrivefast that is the steel one right.
February 27, 2009, 11:15:50 am
TurboJ
February 27, 2009, 11:15:50 am »
No.
You want to use the line that connects to the fuel pump - the mushroom shaped thing on top of that (called LDA). That line should be rubber!
The feed for that should come from the inlet manifold 'elbow' in most cases.
Using that line to fit the 'T' will tell you the pressure that's entering the engine, disrecarding all the pressure drop associated with the possible intercooler, boost pipes etc.
Jetta II 1.6 TD 'Project 200'
February 28, 2009, 09:53:48 am
kaneb
February 28, 2009, 09:53:48 am »
Heres a pic from a local guy.
This should explain all.
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
February 28, 2009, 02:56:18 pm
Jettagli16v
February 28, 2009, 02:56:18 pm »
Depending on where he lives (Update your profile, dude!)
a 1990 TD Jetta in the US is just an Eco,
therefore, no LDA...
I dont know where to tap that but any vacuum line connected to the intake manifold should do fine.
-Brad
Currently: 81 Caddy 1.9 AAZ, 1995 Audi S6, 78 ASI/Riviera camper bus 2.0, 74 THING 1.8 (resto, coming in 2020).
February 28, 2009, 03:38:10 pm
kaneb
February 28, 2009, 03:38:10 pm »
I don't have an LDa with my turbo NA. I run my boost gauge right off the intake manifold with some 1/4" synflex tubing.
Works like a charm.
Kane
www.dasdubbers.org
February 28, 2009, 06:46:36 pm
L1V3N 1T
Newbie
February 28, 2009, 06:46:36 pm »
i have a 1990 jetta wolfsburg and i live in canada
i think i do have the LDA i remember that hose going to it
another question the egt temp what should it range between to be safe??
March 01, 2009, 07:29:18 am
kaneb
March 01, 2009, 07:29:18 am »
If your egt probe is mounted into the exhaust manifold before the turbo max. i would take it up to is 1400.
Kane
www.dasdubbers.org
