Author Topic: FN tranny 5th gearset swap possible?  (Read 6621 times)
February 26, 2009, 07:18:50 am
chiefdiesel
  • 31
« on: February 26, 2009, 07:18:50 am »
Will the .65 or .68 5th gearset work in a FN coded tranny from an '81 Jetta?
2 B4 Passats Ecodes/HID/pp764/rc2
'85 Jetta coupe 1.6 n/a
'80 Caddy 110 (afn) m-tdi/12mm Lt 2.8 ip/.216/fmic
Reply #1February 26, 2009, 12:07:45 pm
Re: FN tranny 5th gearset swap possible?
« Reply #1 on: February 26, 2009, 12:07:45 pm »
Quote from: "chiefdiesel"
Which trans is the gear set out of? If it is out of another 020 then it should work.
Reply #2February 26, 2009, 02:47:52 pm
blkboostedtruck
  • 1535
« Reply #2 on: February 26, 2009, 02:47:52 pm »
where you getting this from? i'm curious! i never heard of those ratios for a 5th!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3February 26, 2009, 04:39:02 pm
Dr. Diesel
  • 1341
« Reply #3 on: February 26, 2009, 04:39:02 pm »
I have a .75 020 fifth set for sale if you're interested.
Reply #4February 26, 2009, 04:52:53 pm
« Reply #4 on: February 26, 2009, 04:52:53 pm »
Quote from: "blkboostedtruck"
Duane
click here and be amazed
Reply #5February 26, 2009, 06:53:40 pm
chiefdiesel
  • 31
« Reply #5 on: February 26, 2009, 06:53:40 pm »
This tranny currently has the .75.  I want the tallest gearset possible for the FN 020
Reply #6February 26, 2009, 06:57:12 pm
« Reply #6 on: February 26, 2009, 06:57:12 pm »
The 020 FN came with the .71
the difference between the .71 that you have, and the .68 or .65 is less then 200 rpm's and like $350
why not stay with the .71?
65 mph will run you 2500 rpm, right where you want to be
Reply #7February 26, 2009, 10:08:29 pm
foxracer1
  • 991
« Reply #7 on: February 26, 2009, 10:08:29 pm »
Some FN's came with a .75 depends on the exact build date.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #8February 27, 2009, 07:22:46 am
« Reply #8 on: February 27, 2009, 07:22:46 am »
Quote from: "jtanguay"
Duane
Those are for the TDI trans. Not the 020.
I cant remember the codes but it's like a 02J or something, cable shift trans.
Reply #9February 27, 2009, 09:29:21 am
« Reply #9 on: February 27, 2009, 09:29:21 am »
Quote from: "foxracer1"
my bad.. lmao
Still tho the diff between .75 and .71 is next to nothing and is it really worth the time and effort?
Reply #10February 27, 2009, 10:11:21 am
« Reply #10 on: February 27, 2009, 10:11:21 am »
Quote from: "zukgod1"
Duane
This works with all manual transmission VWs from 1996 to the present, as well as many older models.
1996 vw's came with an 020 transmission.  except passat TDI's with the 02A transmission?
i'm pretty sure it would work with any 020 5 speed box, but maybe someone can confirm for sure?
Reply #11March 03, 2009, 08:11:16 pm
blacknoise
  • 12
« Reply #11 on: March 03, 2009, 08:11:16 pm »
Those .65, .68 5th gear sets are for a european gearbox application which uses the same shaft design as the 02A and 02J boxes.  That is why they work for those gearboxs.  Not compatible with the old 020.  Swapping a 020 5th gear is intensive and as said previously, the RPM drop isn't huge.  I considered it when I put a gasser box in my '90 Jetta diesel. Decided it was too much to swap gear sets for an extra 100 RPM drop or whatever.  That tranny swap was totally worth it w/o messing with it's innards.   I installed a .658 on my 02A CNT trans (sourced: 97 Passat TDI) for my 86 Golf TDI epic and this gear swap is pretty easy making it worth it in my view.
-B
81 Rabbit TD - AAZ adaption NEED INJECTORS
90 Jetta D - "tall" tranny (code ACN)
86 Golf TDI (building) - 1900rpm@65mph, .205 nozzles, kp39A turbo, H2O IC
Reply #12March 04, 2009, 04:17:12 am
Dr. Diesel
  • 1341
« Reply #12 on: March 04, 2009, 04:17:12 am »
Quote from: "blacknoise"
for an extra 100 RPM drop or whatever. -B
My rabbit's 020 with a .71 5th runs 2350rpm at 100km/h (60mph)
That'd be 2491rpm with a .75 fifth.
Very worth it.
Reply #13March 04, 2009, 04:49:19 am
foxracer1
  • 991
« Reply #13 on: March 04, 2009, 04:49:19 am »
The 5th swap is easy on an 020. I used a gasser box with a .75 5th. we'll see how she runs.
91 S10 305 TPI T56
