Author Topic: FS: Almost new 11mm cylinder head bolts & hardened washe  (Read 4344 times)
February 21, 2009, 02:01:35 pm
gsodonis
  • 14
« on: February 21, 2009, 02:01:35 pm »
FS: one full set of ten 11mm cylinder head bolts from my 1.6NA diesel rabbit. I had these installed for break-in miles only (~ 1000 mi) before installing a turbo and replacing the bolts with ARP studs. These come with ten matching hardened washers.
SOLD
« Last Edit: June 19, 2009, 03:46:15 am by gsodonis »
Reply #1February 21, 2009, 04:32:51 pm
dieselherb1
  • 354
« Reply #1 on: February 21, 2009, 04:32:51 pm »
Don't know if you know, but these are stretch bolts(one stretch per use)
Reply #2February 21, 2009, 05:54:41 pm
gsodonis
  • 14
« Reply #2 on: February 21, 2009, 05:54:41 pm »
Quote from: "dieselherb1"
I've searchd that topic extensively on these boards and opinions are split.
One train of thought is that they are one use only.
Another train of thought is that aren't stretch bolts - just that VW recommends not reusing the original bolts from a diesel that has seen hundreds of thousands of miles and 25 years of service.
I'm offering these for those that believe the latter.
Reply #3February 21, 2009, 08:16:14 pm
« Reply #3 on: February 21, 2009, 08:16:14 pm »
Opinions my be split but I would NEVER I'll say that a little louder NEVER reuse head bolts...!!!!
Reply #4February 22, 2009, 06:12:38 am
gsodonis
  • 14
« Reply #4 on: February 22, 2009, 06:12:38 am »
Quote from: "zukgod1"
I'll take it that you WON'T I'll say it a little louder WON'T be calling dibs then!!!!
Reply #5February 22, 2009, 09:37:49 am
ilikevwdiesel
  • 1202
« Reply #5 on: February 22, 2009, 09:37:49 am »
The Bentley manual sez you can reuse the allen head 11mm bolts but not the star type 12mm bolts. What's up with that?
My Bio
Reply #6February 22, 2009, 12:07:42 pm
  • 3468
    • McScrubbins Body Wash
« Reply #6 on: February 22, 2009, 12:07:42 pm »
I measured stretch bolts i removed with new ones when i did a HG replace ages ago and the tri-square head bolts DO stretch. I didn't have calipers but they were at least 1-2 mm longer. (which is a lot i think for metal that thick).
I agree, re-using head bolts i don't think is a good idea. for what it's worth anyways. New ones aren't exactly expensive.
are yours 11mm allen or 12mm tri-square?
Reply #7February 22, 2009, 04:55:20 pm
gsodonis
  • 14
« Reply #7 on: February 22, 2009, 04:55:20 pm »
11mm allen - the reusable non-stretch variety
Reply #8March 09, 2009, 02:21:05 am
« Reply #8 on: March 09, 2009, 02:21:05 am »
11mm bolts are not stretch bolts. everywhere ive read anything about these motors, states that the 11mm bolts are reuseable. and says they dont stretch. i know how a stretch bolt feels when you torque it.. and they definetly dont stretch. my grandpa and i have re used at least 2 dozen sets of 11mm bolts without a failure.
