Author Topic: uprated headlamp loom  (Read 5436 times)
February 17, 2009, 01:27:41 am
LoneWolf
« on: February 17, 2009, 01:27:41 am »
Does anyone have any photos or diagrams for making the loom?
Reply #1February 17, 2009, 05:56:52 am
saurkraut
  • 904
« Reply #1 on: February 17, 2009, 05:56:52 am »
From http://www.danielsternlighting.com/tech/relays/relays.html
He has a nice kit that includes EVERYTHING but the wires.  I used it on my '79 when I went to E Codes.  All high quality Bosch stuff.  Great kit.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2February 17, 2009, 10:56:35 pm
AudiVWguy
« Reply #2 on: February 17, 2009, 10:56:35 pm »
This might be a stupid question (kids, don't try this at home, I have professional experience asking this stuff)
What if you left the low beam on, and when you hit the brights you added the high beams to the low beams---Super Bright!!   :shock:
It might be worth it to see how long the bulb would last.
Reply #3February 18, 2009, 06:52:17 am
« Reply #3 on: February 18, 2009, 06:52:17 am »
You could just buy a harness ready to go!
http://vwdiesel.net/phpBB/viewtopic.php?t=18181   :D
Reply #4March 15, 2009, 12:15:34 am
JBR8517
  • 20
« Reply #4 on: March 15, 2009, 12:15:34 am »
Eurowires harness is very quality, came with everything including relays and ubber thick wires, just plug/splice into your original harness and "Let there be light!"
http://eurowires.net/
Reply #5March 15, 2009, 02:45:42 am
Op-Ivy
  • 513
« Reply #5 on: March 15, 2009, 02:45:42 am »
Quote from: "AudiVWguy"
I think the bulbs would go pretty quick. I would assume with twice as many filaments burning, there would be twice as much heat! :P
If you try it let me know! I've thought about this before too. (I have an HID setup and can't try it myself)
Reply #6March 15, 2009, 06:09:52 am
« Reply #6 on: March 15, 2009, 06:09:52 am »
In my old Jetta I could hold the high beam switch just before it engaged and both lights would be on. Definitely sounds like a fire hazard if you have stock wiring :shock:
These things are pretty easy to make, and if you look around the net you can find all the pieces you need to make it plug and play, no cutting required.
Reply #7April 02, 2009, 02:31:21 pm
carrizog60
  • 978
« Reply #7 on: April 02, 2009, 02:31:21 pm »
i powered my lamps directly from the batery,why to go to the generator?
also,one of the lights(the farest from the batery) is weaker output,do you know any reason to?
Portugal
Reply #8April 02, 2009, 04:26:54 pm
AudiVWguy
« Reply #8 on: April 02, 2009, 04:26:54 pm »
The weaker head lamp has a ground problem. It would be a good idea to check and add another seperate ground if needed.
Reply #9April 17, 2009, 01:18:04 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #9 on: April 17, 2009, 01:18:04 pm »
8)
Reply #10April 17, 2009, 02:38:01 pm
79rabbit4dr
« Reply #10 on: April 17, 2009, 02:38:01 pm »
i know i'm a little late on this but thought i'd chime in being that i tried this 6 months ago or so on a stock 81. was driving home one night and pulled the brights lever just before it clicks and both high and low beams were on for about 2 minutes and which point and released the lever and my drivers side bulb exploded. Again, everything on my rig was stock but it wasn't worth it. However, I used to do this on my '02 chevy s-10 extreme so that my fog/high/low's were all on... that was nice on dark nights. Maybe upgraded/new equipment would handle it a lot longer... but it's still probably better to just add more lights imo.
Reply #11April 17, 2009, 03:07:01 pm
VWCaddy
  • 85
    • VW Caddy Page
« Reply #11 on: April 17, 2009, 03:07:01 pm »
Here is the plug-n-play harness I run in my '82:
- http://www.4crawler.com/Diesel/CheapTricks/Headlights.shtml#WiringHarness
Best thing you can do on an older VW.  Stock wiring that is 20+ years old and that tired headlight switch (that is NLA) will thank you!  I measured a nearly doubling in my headlight output with just a new harness.
- http://www.4crawler.com/Diesel/CheapTricks/Headlights.shtml#Results
'82 VW pickup, 1.9D engine, Missing LinkZ shift linkage
Reply #12April 18, 2009, 07:06:21 am
« Reply #12 on: April 18, 2009, 07:06:21 am »
I prefer running the ground directly to the battery rather then chassis ground. At $40 that's a great price. What gauge of wire is it?
Reply #13April 18, 2009, 12:17:46 pm
VWCaddy
  • 85
    • VW Caddy Page
« Reply #13 on: April 18, 2009, 12:17:46 pm »
Quote from: "burn_your_money"
Yes, you can always extend the ground wires back to the battery if desired.  Wiring sizes as noted:
http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#TechInfo
