Author Topic: Front Struts  (Read 3694 times)
January 29, 2009, 01:50:12 am
  • 3468
    • McScrubbins Body Wash
Front Struts
« on: January 29, 2009, 01:50:12 am »
[1990 jetta]
OK
I've had these coil overs in my garage for over a year now probably and they're starting to drive me crazy.
I replaced the rear springs with the coil overs no prob, easy stuff.
I took the nuts off the top of the front struts with an impact gun and then took the struts completely off the car after a lot of swearing and fussing with spring compressors.
The strut doesn't want to come apart  :? IT seems to have some weird nut of sorts down the shaft at the top holding it all together and stopping the spring from being able to be removed.
I DID a searchzor and i found something about "inserts" ? ...  not sure what that was about.
Anyone with some insight i'd love to hear it. I really want to finish lowering my car and to stop driving around looking like i have 10 bodies in the trunk.
So, in short... How do you replace the springs on front struts.
Reply #1January 29, 2009, 02:39:49 am
clbanman
  • 705
    Cambridge, Ontario
Front Struts
« Reply #1 on: January 29, 2009, 02:39:49 am »
Compress your springs to get the load off that nut.  I used a socket (can't remember what size) that best fit the I.D./O.D. of the nut and used a grinder to remove material on both sides to leave two tabs to fit in the slots.  I have also removed them using a drift punch and hammer, lightly tapping in the proper direction.  The key is getting the spring load off the nut.
Calvin
91 VW Golf 1.6NA 5spd
Reply #2January 29, 2009, 06:23:55 am
  • 1739
Front Struts
« Reply #2 on: January 29, 2009, 06:23:55 am »
There is a tool available, and not just from snap-on or VW. There are enough VW's out there that a good auto parts place can find and or order one for you.Or do what clbanman said and use a deep socket, and grind down the outside edged untill the 2 tabs left fit into the slots. Get the tension off the bearing and turn them by hand.
Reply #3January 29, 2009, 11:27:09 am
commuter boy
  • 277
Front Struts
« Reply #3 on: January 29, 2009, 11:27:09 am »
I have both of the VW strut tools if you need to borrow them.
http://www.germanautoparts.com/Tools/Volkswagen/Suspension+tools
Slotted strut nut tool & the Upper strut nut socket, 21/22mm
Reply #4January 30, 2009, 12:08:01 am
  • 3468
Front Struts
« Reply #4 on: January 30, 2009, 12:08:01 am »
Quote from: "commuter boy"
No way! PM SENT! :D
