Author Topic: SHE LIVES!!!  (Read 3654 times)
January 27, 2009, 10:02:53 am
96jetta
SHE LIVES!!!
« on: January 27, 2009, 10:02:53 am »
most of you guys probaly now what i did to my poor little deisel :(. but i finally got her running strong. how ever i noticed at idel the oil pres was at 40psi is this normal? as well as there was some coolent in the oil. i did change the head guasket so i wasnt sure if this is what happens during the break in of the new guasket.
and for all of you guys in this site you have been an amazing help and appreciat it alot :D
                            thanks Geoff (96jetta)
Reply #1January 27, 2009, 10:20:18 am
arb
SHE LIVES!!!
« Reply #1 on: January 27, 2009, 10:20:18 am »
Coolant in the oil will be bad if it continues. I'd change / flush the oil and be sure it was from assembly and not a leak.
Reply #2January 27, 2009, 11:19:09 am
96jetta
SHE LIVES!!!
« Reply #2 on: January 27, 2009, 11:19:09 am »
is there a way to test for a leake in the saytem? like a color in the exaust or a pressure test?
Reply #3January 27, 2009, 11:24:29 am
arb
SHE LIVES!!!
« Reply #3 on: January 27, 2009, 11:24:29 am »
Quote from: "96jetta"
40 psi should be good. Was that at idle  or some speed ?
For coolant leaks into the oil, I only know of seeing the contaminate in the oil. If you are at operating temp, and don't see the leak for a while, the oil will become a milky constancy as they mix.
Reply #4January 27, 2009, 11:33:26 am
96jetta
SHE LIVES!!!
« Reply #4 on: January 27, 2009, 11:33:26 am »
ya 40psi was at idel so that sounds good if ur givin the ok. i think im just more parinoied at what hasnt happened but could happen. but in regards to the coolent\oil ging on if i change it it should go away. but if it stays what should i look for\ change to get rid of the problem?
Reply #5January 27, 2009, 12:24:45 pm
SHE LIVES!!!
« Reply #5 on: January 27, 2009, 12:24:45 pm »
40 psi hot idle? that seems pretty high!  not really a bad thing though...
Reply #6January 27, 2009, 12:29:51 pm
arb
SHE LIVES!!!
« Reply #6 on: January 27, 2009, 12:29:51 pm »
If you keep getting coolant in the oil, a blown head gasket is the most common I've seen. A cracked head can do this too, but that usually happens when over heated, so you head could be warped too.
I would not get excited until you change the oil. How much coolant is in your oil ? A small amount is normal when you pull the head. Did you change the oil after you assembled it ?
Reply #7January 27, 2009, 12:57:24 pm
96jetta
SHE LIVES!!!
« Reply #7 on: January 27, 2009, 12:57:24 pm »
ya but i didnt fully rain the coolent or oil when i disassembles i just let it drain out when loosened the head bolts off
Reply #8January 27, 2009, 01:19:06 pm
arb
SHE LIVES!!!
« Reply #8 on: January 27, 2009, 01:19:06 pm »
Sounds like its from the head being pulled... dump & change the filter - I pour a donor quart of oil through as a rinse before replacing the drain plug. Use Mobil-1 and you'll see better mpg and starts.
Reply #9January 27, 2009, 01:23:09 pm
96jetta
SHE LIVES!!!
« Reply #9 on: January 27, 2009, 01:23:09 pm »
it doesn't seem to be getting any worse. it was idling for a good 30 min and it stayed the same visual amount. i think im just paranoid after all its only my 1st build lol
Reply #10January 27, 2009, 01:31:44 pm
  • 3468
    • McScrubbins Body Wash
SHE LIVES!!!
« Reply #10 on: January 27, 2009, 01:31:44 pm »
oil floats on water (coolant/water will sink, correct?)
you can drive it for like a week then let it sit for an hour or two and undo the oil pan bolt just ever so much! and catch the first few drips and see if it's oil; or ... something else! :o
just my thoughts. they could be horribly scewed and dismally wrong but you won't damage anything by doing that, depending on how long you drive for before you check it again.
Reply #11January 27, 2009, 01:53:13 pm
96jetta
SHE LIVES!!!
« Reply #11 on: January 27, 2009, 01:53:13 pm »
im planning on just cleaning all the oil out again tonight any way so well see what it looks like. the coolant holder has nothing but coolant in it. usually the oil would float to the top of that so im hoping its just coolant thats left from in the oil lines in the block from pulling the head lol
Reply #12January 28, 2009, 08:20:11 am
arb
SHE LIVES!!!
« Reply #12 on: January 28, 2009, 08:20:11 am »
It depends on how much coolant you have and how long you run it at temp. Either way, it is bad news for your cam - your oil pickup at the bottom of the pan where the coolant will settle - not good for lubrication. Also, if its hot, the oil pump does a good job of homogenizing the mixture short term. Not a good lube.
Reply #13January 28, 2009, 05:51:40 pm
SHE LIVES!!!
« Reply #13 on: January 28, 2009, 05:51:40 pm »
If your burning the coolant   which I dont't think you are     It will be a white color and smells funny. I believe the water/coolant mix retards and cools down the injection and you get the unburnt white out the exhuast.
Reply #14January 28, 2009, 06:42:40 pm
truckinwagen
  • 1895
SHE LIVES!!!
« Reply #14 on: January 28, 2009, 06:42:40 pm »
the coolant itself burns white(steam) and smells sweet.
my dads suburban blew a HG and it blew so much white smoke for a while that it would disappear when stopped at a light.
83 Opel Kadett Diesel
