Author Topic: running lean?  (Read 4681 times)
January 22, 2009, 04:38:22 pm
shopro88
  • 8
running lean?
« on: January 22, 2009, 04:38:22 pm »
I just had the catylitic converter gutted on my jetta ecodiesel. It runs ALOT better, maybe too good. It runs a little bit warmer, and since it is td motor with a NA pump  I was thinking it might be leaning for some reason. could gutting the cat on my eco lean it out?
Reply #1January 22, 2009, 06:52:20 pm
running lean?
« Reply #1 on: January 22, 2009, 06:52:20 pm »
no
The way I understand a diesel takes in 100% of cylinder volume per stroke. It maybe breathing better, but the more air you get in and out faster it should run cooler. The hot part is when you turn up the fuel.
Reply #2January 22, 2009, 09:35:26 pm
  • 1739
running lean?
« Reply #2 on: January 22, 2009, 09:35:26 pm »
Quote from: "theman53"
no
well, not "no". you are both saying the same thing.
Reply #3January 22, 2009, 10:57:23 pm
79rabbit4dr
running lean?
« Reply #3 on: January 22, 2009, 10:57:23 pm »
I think "theman53" was answering "shopro88's" question, not refuting "libbybapa's" post  :)
Reply #4January 23, 2009, 03:35:20 am
running lean?
« Reply #4 on: January 23, 2009, 03:35:20 am »
yeah Libbybapa posted sooner than I did, but it looks like we basically were righting at the same time. Andrew just must be a faster typer than me  :lol:
Reply #5January 23, 2009, 06:58:40 am
arb
Re: running lean?
« Reply #5 on: January 23, 2009, 06:58:40 am »
Quote from: "shopro88"
Like they all said, a diesel is always lean - we control power (aside from boost on some engines) by controlling how much fuel is injected... so, less fuel, less power. If your Cat is plugged, you'll have excessive back pressure which means less clean air in each combustion cycle, so less power and less heat because there is not as much air to burn the fuel.
Reply #6January 23, 2009, 02:51:12 pm
88jetta350
Re: running lean?
« Reply #6 on: January 23, 2009, 02:51:12 pm »
Why didn't you just replace it?
Reply #7January 23, 2009, 05:21:53 pm
dillenger1
  • 777
Re: running lean?
« Reply #7 on: January 23, 2009, 05:21:53 pm »
Quote from: "88jetta350"
replace it?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #8January 23, 2009, 08:43:45 pm
Re: running lean?
« Reply #8 on: January 23, 2009, 08:43:45 pm »
Quote from: "dillenger1"
replace it?
Why not take it off completely? :P
Reply #9January 24, 2009, 12:47:43 am
  • 3468
    • McScrubbins Body Wash
running lean?
« Reply #9 on: January 24, 2009, 12:47:43 am »
HA!
my pops said today "how much would an exhaust system cost for your car? because we just want it out of the garage."
"Well, because i need a downpipe to be fabricated to fit because of the blend of two different sized engines and i want it to be three inch exhaust... probably $1,000 for a shop and like ... $150 if i did it my self + beers and SS wire because i already have some three inch pipe, oh and probably a weekend... and i wouldnt get a catalytic converter or a muffler"
(he seemed to think those two items were vital)
"oh..."
For air care im just going to get two adapters that will replace a piece of my straight pipe with the old cat for air care purposes only :P Muffler isn't required.
Reply #10January 24, 2009, 05:29:21 pm
shopro88
  • 8
running lean?
« Reply #10 on: January 24, 2009, 05:29:21 pm »
thanks guys. It dose run alot better now. I had my buddy took its temp and it was around 190F. It might need a sending unit, It runs on the second to last line (3/4) I would call it.
Reply #11January 24, 2009, 11:41:41 pm
Rabbit TD
  • 840
Re: running lean?
« Reply #11 on: January 24, 2009, 11:41:41 pm »
Quote from: "arb"
This might sound dumb but I didn't know these 1.6's even had catalytic converters, I didn't think diesel would work with a catalytic converter and just kill the workings of it :oops: All mine have just had a resonator and a muffler :shock:
Reply #12January 25, 2009, 10:21:01 am
spencebm
  • 686
running lean?
« Reply #12 on: January 25, 2009, 10:21:01 am »
cats suck and all they do is get plugged up with soot and then do no good but add weight, DON'T DO IT
Ben Spencer
Reply #13January 25, 2009, 10:24:53 am
dillenger1
  • 777
running lean?
« Reply #13 on: January 25, 2009, 10:24:53 am »
why did you put the cat back in?
Reply #14January 25, 2009, 02:38:20 pm
shopro88
  • 8
running lean?
« Reply #14 on: January 25, 2009, 02:38:20 pm »
It was easier just to gut the cat then to bend pipe in its place.
