Author Topic: 6-speed tranny question  (Read 6117 times)
Reply #15January 24, 2009, 02:16:06 pm
« Reply #15 on: January 24, 2009, 02:16:06 pm »
Quote from: "foxracer1"
So will those gear sets fit an 020?
as far as i know they will.
Reply #16January 27, 2009, 06:35:53 am
nogama3
  • 162
« Reply #16 on: January 27, 2009, 06:35:53 am »
just how much work is involved to make it fit?
Reply #17January 27, 2009, 06:50:22 am
« Reply #17 on: January 27, 2009, 06:50:22 am »
Quote from: "nogama3"
not much... it can actually be done while in the car.  just follow the online instructions.  the best way to get the gears out is not with a puller, but to actually heat them up.  then they will just slide right off.  i seem to recall that you can actually break something inside if you use a puller... maybe the gear itself???  :shock:
Reply #18February 13, 2009, 11:09:46 am
CoolAirVw
  • 175
« Reply #18 on: February 13, 2009, 11:09:46 am »
If your asking about the gear sets on kermatdi and tdiparts... they are for a 02J in the a4 platform and will not fit a 020.
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #19February 13, 2009, 12:42:04 pm
« Reply #19 on: February 13, 2009, 12:42:04 pm »
Reply #20April 06, 2009, 06:52:55 am
CoolAirVw
  • 175
« Reply #20 on: April 06, 2009, 06:52:55 am »
Quote from: "jtanguay"
http://www.boraparts.com/catalog/product_info.php?products_id=70
that gearset should fit on an 020.
That link goes to a gearset for a o2j.  I guess it does say "fits 96 and newer and some older" (paraphrase)
Are you saying that some 020 and 02j's have interchangeable gears?
75 Porsche 914
93 GMC Truck
Reply #21April 06, 2009, 09:12:56 am
arb
« Reply #21 on: April 06, 2009, 09:12:56 am »
If you can squeeze taller tires on your car, you'll also drop your rpm...
Reply #22April 06, 2009, 02:37:55 pm
ein bora
  • 377
« Reply #22 on: April 06, 2009, 02:37:55 pm »
Quote from: arb
If you can squeeze taller tires on your car, you'll also drop your rpm...[/quote
Actually I thought of that - I'm running 195-60x14" which is a 23.2" tall  tire now, I think it could easily handle a 195-65x14" which is 24" tall or maybe even a 195-70x14" which is 24.7" tall, both are the same width as the 195-60x14's. Expensive gamble though - fitment wise.
If you can't take advice - then you can't be helped!
Reply #23April 06, 2009, 03:47:10 pm
hamradio
  • 282
« Reply #23 on: April 06, 2009, 03:47:10 pm »
How fast are you cruising at?  Why not use a .71 out of a lot of old diesel 020's?
I don't have a tach, but the .71 in my rabbit is actually a little too tall for my taste.
FYI, early dodge omni 4sp's were vw transmissions with a tall r&p, I think.
Reply #24April 06, 2009, 04:53:43 pm
« Reply #24 on: April 06, 2009, 04:53:43 pm »
i'm installing a CTN in my mk2 jetta.  it has the tallest r&p available, but the 5th gear can still go lower  8)  .  i'll be bolting the clutch master cyl to the firewall and then putting a rod from the clutch pedal to it with the right angle. way cheaper than doing the cable conversion, plus i kinda like hydraulic  :lol:
also going cable clutch will be cool! 2100 rpm is nearly 60 mph.   8)
