Author Topic: Please answer my easy/stupid question  (Read 2247 times)
January 18, 2009, 12:13:11 pm
boosted_diesel_84
  • 216
« on: January 18, 2009, 12:13:11 pm »
when installing a new thermostat, which way does the arrow face?
my bentley manual is about 10 miles from me and i have no way to get it.
i am assuming facing up, but since its a vw...... it may go sideways lol.
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #1January 18, 2009, 01:31:13 pm
b1rdjx88
« Reply #1 on: January 18, 2009, 01:31:13 pm »
The side with the exposed springs points up.
Reply #2January 18, 2009, 01:56:32 pm
boosted_diesel_84
  • 216
« Reply #2 on: January 18, 2009, 01:56:32 pm »
i know which way it goes, lol, but there is an arrow that can be rotated 360 degrees around, i am assuming facing UP,
Reply #3January 18, 2009, 02:25:14 pm
dieselweasel
  • 312
« Reply #3 on: January 18, 2009, 02:25:14 pm »
I wouldn't think it would matter.  I've never seen a t-stat that was directional around ie 0 degrees or 90...t-stats are always the same all the way around.
Reply #4January 18, 2009, 02:34:36 pm
boosted_diesel_84
  • 216
« Reply #4 on: January 18, 2009, 02:34:36 pm »
i w9ill post a pic both old and new had one, i figured it wold only matter if it had an air bleed on it, but neither did.so idk. its in, and my rad is getting hot and circulating coolant now, so im happy.
Reply #5January 19, 2009, 01:08:36 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #5 on: January 19, 2009, 01:08:36 pm »
Don't forget the superglue! :D
