Please answer my easy/stupid question
Topic: Please answer my easy/stupid question (Read 2240 times)
January 18, 2009, 12:13:11 pm
boosted_diesel_84
January 18, 2009, 12:13:11 pm »
when installing a new thermostat, which way does the arrow face?
my bentley manual is about 10 miles from me and i have no way to get it.
i am assuming facing up, but since its a vw...... it may go sideways lol.
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread
http://www.vwdiesel.net/forum/index.php?topic=15461.0
January 18, 2009, 01:31:13 pm
b1rdjx88
January 18, 2009, 01:31:13 pm »
The side with the exposed springs points up.
January 18, 2009, 01:56:32 pm
boosted_diesel_84
January 18, 2009, 01:56:32 pm »
i know which way it goes, lol, but there is an arrow that can be rotated 360 degrees around, i am assuming facing UP,
January 18, 2009, 02:25:14 pm
dieselweasel
January 18, 2009, 02:25:14 pm »
I wouldn't think it would matter. I've never seen a t-stat that was directional around ie 0 degrees or 90...t-stats are always the same all the way around.
January 18, 2009, 02:34:36 pm
boosted_diesel_84
January 18, 2009, 02:34:36 pm »
i w9ill post a pic both old and new had one, i figured it wold only matter if it had an air bleed on it, but neither did.so idk. its in, and my rad is getting hot and circulating coolant now, so im happy.
January 19, 2009, 01:08:36 pm
smutts
ClackClackClackClackClack
January 19, 2009, 01:08:36 pm »
Don't forget the superglue!
