Author Topic: FS: 1Z/AHU engine parts  (Read 4952 times)
January 18, 2009, 11:45:55 am
bryanbryan89x
  • 110
« on: January 18, 2009, 11:45:55 am »
- Complete AHU/1Z cylinder head, 150k miles on it.  worked good when pulled - $400 shipped
- (2) water pump housings - $25 each shipped
- (2) alt and AC  bracket with tensioner - $45 ea. shipped
- (1) crank sprocket - $25 shipped
- Upper timing belt cover - $25 shipped
- Lower timing belt cover $25 shipped
- Power steering pump - $35 shipped
- AC condenser - $80 shipped
- 120 amp alternator cracked plastic electrical housing, but worked good, $60 shipped
1981, Rabbit Car, 1.6, N.A.
Reply #1January 19, 2009, 03:51:19 pm
« Reply #1 on: January 19, 2009, 03:51:19 pm »
By crank pulley, do you mean timing belt or balancer/ribbed belt?
Reply #2January 21, 2009, 05:27:18 am
bryanbryan89x
  • 110
« Reply #2 on: January 21, 2009, 05:27:18 am »
Quote from: "jimfoo"
Good question, that was a poor choice of words on my part, I actually meant "crank sprocket" the one that runs the TB, I have fixed the O.P.
Reply #3January 23, 2009, 03:28:57 pm
88jetta350
« Reply #3 on: January 23, 2009, 03:28:57 pm »
I'll be getting in touch with you soon about that Alt/A/C bracket. I just need to verify that I'm getting my swap car.
Reply #4January 24, 2009, 02:24:10 pm
foxracer1
  • 991
« Reply #4 on: January 24, 2009, 02:24:10 pm »
How about the vacum pump? I'm swapping from a 1.6 idi so i need the little things that are different.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #5January 26, 2009, 11:38:17 am
bryanbryan89x
  • 110
« Reply #5 on: January 26, 2009, 11:38:17 am »
Quote from: "foxracer1"
PM sent
Reply #6January 27, 2009, 12:08:18 am
  • 2932
« Reply #6 on: January 27, 2009, 12:08:18 am »
What happened to the bottom end?
 I need to look at an oil ring out of one of the pistons.
Reply #7January 29, 2009, 11:52:57 am
bryanbryan89x
  • 110
« Reply #7 on: January 29, 2009, 11:52:57 am »
I have the bottom end, the block cracked, but all internals should be good.
