Author Topic: lifter help  (Read 1916 times)
January 18, 2009, 10:39:12 am
96jetta
lifter help
« on: January 18, 2009, 10:39:12 am »
the crank bolt slipped letting the cam destroy the lifters. i got 6 out but 2 are seased in there is there any way of gettting them out??
Reply #1January 18, 2009, 11:32:24 am
veedubcanuck
  • 151
lifter help
« Reply #1 on: January 18, 2009, 11:32:24 am »
Again?!?!
2003 Jetta GLS 1.8T w/ Upsolute software 20k kms (yes 20)
1993 Jetta GL 1.9TD stock 440k kms
1990 Jetta 1.6TD stock 320k kms
1993 Golf GL 1.9TD stock 401k kms
1991 Jetta 1.6TD Stock 587k kms
Reply #2January 18, 2009, 12:21:30 pm
96jetta
lifter help
« Reply #2 on: January 18, 2009, 12:21:30 pm »
ya i have absolutly no luck with this car what so ever :evil:. i finally got it started last night   :lol:. then it just stopped. so i get it to TDC. and the cam slipped 90 deg. ***!!!. so i checked the crank sprocket and the little nubs on it had sheared off. so im assuming thats where my problem was in the first place   :oops:. so once again i have to build up the head and get a new sprocket and bolt for the crank and pray that all gors right then 2nd time around
Reply #3January 18, 2009, 12:54:00 pm
Quantum TD
  • 1195
lifter help
« Reply #3 on: January 18, 2009, 12:54:00 pm »
Ouch.
Sounds like the lifters mushroomed into the lifter bores. I'd take it to a shop to get them out. You'll need to hone/fill/rebore the lifter bores after that.
You may just want to junk the head if that's possible. If you've got an AAZ, I guess heads are hard to come by, so good luck either way.
