lifter help
Topic: lifter help (Read 1921 times)
January 18, 2009, 10:39:12 am
96jetta
lifter help
January 18, 2009, 10:39:12 am »
the crank bolt slipped letting the cam destroy the lifters. i got 6 out but 2 are seased in there is there any way of gettting them out??
January 18, 2009, 11:32:24 am
veedubcanuck
lifter help
January 18, 2009, 11:32:24 am »
Again?!?!
January 18, 2009, 12:21:30 pm
96jetta
lifter help
January 18, 2009, 12:21:30 pm »
ya i have absolutly no luck with this car what so ever :evil:. i finally got it started last night :lol:. then it just stopped. so i get it to TDC. and the cam slipped 90 deg. ***!!!. so i checked the crank sprocket and the little nubs on it had sheared off. so im assuming thats where my problem was in the first place :oops:. so once again i have to build up the head and get a new sprocket and bolt for the crank and pray that all gors right then 2nd time around
January 18, 2009, 12:54:00 pm
Quantum TD
lifter help
January 18, 2009, 12:54:00 pm »
Ouch.
Sounds like the lifters mushroomed into the lifter bores. I'd take it to a shop to get them out. You'll need to hone/fill/rebore the lifter bores after that.
You may just want to junk the head if that's possible. If you've got an AAZ, I guess heads are hard to come by, so good luck either way.
lifter help
