For Sale/Looking For
Parts for Sale/Wanted
What kind of engine is this (pictures)
Topic: What kind of engine is this (pictures) (Read 4773 times)
January 07, 2009, 04:16:09 pm
zyewdall
January 07, 2009, 04:16:09 pm »
http://s141.photobucket.com/albums/r66/driftingouttosea/vw_diesel/?action=view¤t=DSC_0106.jpg
They kind of look like TDI's to me.... but missing the turbos. Hmmm? There's two of them, but I'm not quite sure what they are (having mostly seen old 1.6's...)
Thanks
Z
'84 Mitsubishi 4x4 2.3L turbo biodiesel pickup
'91 VW Rabbit GTI with 1.6 biodiesel transplant
'81 Toyota longbed 2wd 2.2NA biodiesel pickup (for sale)
'89 Subaru 4x4 touring wagon
'82 subaru 4x4 TDI wagon -- project on hold
1976 Ford Sasquatch pickup
January 07, 2009, 04:43:21 pm
CODE4LS1
January 07, 2009, 04:43:21 pm »
That looks ike a 1.9 TDI to me....
January 07, 2009, 06:05:18 pm
79rabbit4dr
January 07, 2009, 06:05:18 pm »
looks pretty clean, you should be able to pull an engine code and find out, right?
January 07, 2009, 08:48:54 pm
Powered by Spearco
January 07, 2009, 08:48:54 pm »
Yep, TDI. Looks like an AHU engine code the way the exhaust manifold is. Worked on one today. Not as clean though.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
January 07, 2009, 08:49:55 pm
January 07, 2009, 08:49:55 pm »
they look like tdis with out a turbo to me, looks like a turbo exhaust manifold on them
January 07, 2009, 09:05:03 pm
96jetta
January 07, 2009, 09:05:03 pm »
i agree its an AHU TDI. the injection pump doesn't have a mechanical throttle
January 09, 2009, 10:11:57 am
zyewdall
January 09, 2009, 10:11:57 am »
Thanks...
So if they are AHU code TDI's, do they share the same mechanical connections (bolt pattern, flywheel, etc) as the older 1.6/1.8 engines? Just wondering if they'd be useable in an older car (if the electronic control can be worked out, that is....)
Z
January 09, 2009, 05:18:20 pm
January 09, 2009, 05:18:20 pm »
I'm 90% sure that the early TDIs are the same as the 1.6/1.8s.
In the event that you don't want to worry about electronics you can always have a mTDI pump built
January 09, 2009, 05:31:41 pm
rallydiesel
January 09, 2009, 05:31:41 pm »
If it's an AHU then the block is virtually identical to the 1.9 IDI block aside from the pistons. So yes, it can be tossed into a mk2 but you will need to deal with the electronics.
1991 Jetta TD - sold
2001 Golf TDI - Son's
