Author Topic: What kind of engine is this (pictures)  (Read 4765 times)
January 07, 2009, 04:16:09 pm
zyewdall
  • 393
« on: January 07, 2009, 04:16:09 pm »
http://s141.photobucket.com/albums/r66/driftingouttosea/vw_diesel/?action=view&current=DSC_0106.jpg
They kind of look like TDI's to me.... but missing the turbos.  Hmmm?  There's two of them, but I'm not quite sure what they are (having mostly seen old 1.6's...)
Thanks
Z
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
Reply #1January 07, 2009, 04:43:21 pm
CODE4LS1
  • 73
« Reply #1 on: January 07, 2009, 04:43:21 pm »
That looks ike a 1.9 TDI to me....
Reply #2January 07, 2009, 06:05:18 pm
79rabbit4dr
« Reply #2 on: January 07, 2009, 06:05:18 pm »
looks pretty clean, you should be able to pull an engine code and find out, right?
Reply #3January 07, 2009, 08:48:54 pm
Powered by Spearco
  • 1203
« Reply #3 on: January 07, 2009, 08:48:54 pm »
Yep, TDI. Looks like an AHU engine code the way the exhaust manifold is. Worked on one today. Not as clean though.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #4January 07, 2009, 08:49:55 pm
« Reply #4 on: January 07, 2009, 08:49:55 pm »
they look like tdis with out a turbo to me, looks like a turbo exhaust manifold on them
Reply #5January 07, 2009, 09:05:03 pm
96jetta
« Reply #5 on: January 07, 2009, 09:05:03 pm »
i agree its an AHU TDI. the injection pump doesn't have a mechanical throttle
Reply #6January 09, 2009, 10:11:57 am
zyewdall
  • 393
« Reply #6 on: January 09, 2009, 10:11:57 am »
Thanks...
So if they are AHU code TDI's, do they share the same mechanical connections (bolt pattern, flywheel, etc) as the older 1.6/1.8 engines?  Just wondering if they'd be useable in an older car (if the electronic control can be worked out, that is....)
Z
Reply #7January 09, 2009, 05:18:20 pm
« Reply #7 on: January 09, 2009, 05:18:20 pm »
I'm 90% sure that the early TDIs are the same as the 1.6/1.8s.
In the event that you don't want to worry about electronics you can always have a mTDI pump built
Reply #8January 09, 2009, 05:31:41 pm
rallydiesel
  • 1880
« Reply #8 on: January 09, 2009, 05:31:41 pm »
If it's an AHU then the block is virtually identical to the 1.9 IDI block aside from the pistons. So yes, it can be tossed into a mk2 but you will need to deal with the electronics.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
