Author Topic: AAZ pulleys question  (Read 2792 times)
January 02, 2009, 04:37:11 pm
Grunttorque
  • 19
« on: January 02, 2009, 04:37:11 pm »
I'm doing a aaz samurai swap and almost have everything in order to do it but the 97 engine I got has a serpentine setup on it. My problem is I want to use the other belts instead since Im not running power steering or ac and am using the stock suzuki alternator.  Does anyone know the best way to convert the crank pulley and waterpump over? thanks in advance!
Nick
88 Samurai soon to be 1.9TD
08 Harley F350 6.4l
Reply #1January 02, 2009, 05:55:57 pm
dillenger1
  • 777
« Reply #1 on: January 02, 2009, 05:55:57 pm »
you mean to v-belt status?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2January 02, 2009, 06:42:36 pm
« Reply #2 on: January 02, 2009, 06:42:36 pm »
nonono... you don't want to go to v-belts.  it can be done, but its more trouble than worth.  you can simply remove the a/c pump.  you'll need a non a/c w/p pulley though... and a shorter serp belt.  then you can also remove the p/s pump and run it as is.
Reply #3January 02, 2009, 07:28:40 pm
Grunttorque
  • 19
« Reply #3 on: January 02, 2009, 07:28:40 pm »
hmm ya I might stick with the serp setup. but the wrecking yard took everything off the engine. Do you guys know if there is an idler pulley or tensioner I need to get? Thanks
08 Harley F350 6.4l
Reply #4January 03, 2009, 07:29:23 am
« Reply #4 on: January 03, 2009, 07:29:23 am »
check the FAQ section for the serp setup on a 1.6 thread I made. It will show you pictures of both the AC and non AC versions.
Reply #5January 03, 2009, 10:43:04 am
Grunttorque
  • 19
« Reply #5 on: January 03, 2009, 10:43:04 am »
Wow good info thanks I was looking all over for a belt routing diagram but the real thing is even better..
08 Harley F350 6.4l
