Author Topic: 93 Jetta Blower Motor Problem  (Read 4043 times)
December 22, 2008, 03:54:19 pm
Kantdrive55
  • 65
    • http://www.dieselperformance.com
« on: December 22, 2008, 03:54:19 pm »
My fan level 1 and 3 havent worked for a while.  2 and 4 always have until today.  Could this be a switch problem?  Thanks
1993 TD Jetta
Cold air intake,pump tweaked,2.5" exhaust and more to come.
Reply #1December 22, 2008, 05:07:06 pm
Re: 93 Jetta Blower Motor Problem
« Reply #1 on: December 22, 2008, 05:07:06 pm »
Quote from: "Kantdrive55"
definitely.
Reply #2December 31, 2008, 09:26:01 am
Kantdrive55
  • 65
« Reply #2 on: December 31, 2008, 09:26:01 am »
Will the controller that is for AC work on a vehicle that doesnt have ac?
1993 TD Jetta
Reply #3January 01, 2009, 09:47:06 pm
Kantdrive55
  • 65
« Reply #3 on: January 01, 2009, 09:47:06 pm »
Anybody know if the AC heater controls will work on non ac car?
1993 TD Jetta
Reply #4January 02, 2009, 07:59:38 am
andy2
« Reply #4 on: January 02, 2009, 07:59:38 am »
The controls for A/C cars are vaccum operated and on non A/C cars they are cable operated.I'm pretty sure everything including the switch is different.I havn't seen all fan speeds quit working before usually Hi speed works when the rest don't.Could possibly be the motor or a fuse.If the switch contacts are worn you should be able to wiggle the swich around to get contact.I'm not sure if there cars have a fan motor resitor control for the fan speeds???
Reply #5January 04, 2009, 11:04:20 am
Kantdrive55
  • 65
« Reply #5 on: January 04, 2009, 11:04:20 am »
Thanks for the info.  I can only get 4 to work.  The blower works fine.  I just have to be able to control it now.  I have to wiggle the switch to just the right spot to get it to work, so I am pretty sure it is the switch.
1993 TD Jetta
