Author Topic: What is this. Info please  (Read 4156 times)
December 16, 2008, 01:07:56 pm
Powered by Spearco
  • 1203
« on: December 16, 2008, 01:07:56 pm »
Seems to be an ALH TDI block and head, but the turbo looks like its from an AHU. The pump looks like it from an AAZ, PN 028 130 108 A, but it doesn't have the adjustable pump sprocket  :? . This all was in a MK1 Rabbit. How would it run if the pump sprocket is not the right one, or am I missing something here about the conversion?
Josh
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #1December 16, 2008, 01:39:08 pm
Turbinepowered
  • 1206
Re: What is this. Info please
« Reply #1 on: December 16, 2008, 01:39:08 pm »
Quote from: "Powered by Spearco"
That's a funky orientation for the IP.
And what's the other cogged sprocket there, lower and to the left (blockward) from the IP? Looks like it's in the pathway of the timing belt... oil pump? Intermediate shaft? Weird.
I dunno what to tell you, honestly.  :shock:
Reply #2December 16, 2008, 01:52:47 pm
blackdogvan
  • 574
« Reply #2 on: December 16, 2008, 01:52:47 pm »
AAZ based pump? Looks like 17mm pump shaft...
1991 Vanagon 1.9 mTDI
Reply #3December 16, 2008, 02:26:08 pm
veedubcanuck
  • 151
« Reply #3 on: December 16, 2008, 02:26:08 pm »
"And what's the other cogged sprocket there, lower and to the left (blockward) from the IP? Looks like it's in the pathway of the timing belt... oil pump? Intermediate shaft? Weird."
  :idea:  That's the water pump I believe. :idea:
Reply #4December 16, 2008, 02:57:54 pm
Powered by Spearco
  • 1203
« Reply #4 on: December 16, 2008, 02:57:54 pm »
Yep. its a T-belt driven water pump. Below that is an idler and then the crank sproket.
The pump is what realy  :? me. I know its not an m-tdi pump.
'13 Golf R:. Tuned
'98 Puch G320
Reply #5December 16, 2008, 04:07:36 pm
« Reply #5 on: December 16, 2008, 04:07:36 pm »
Quote from: "libbybapa"
What brings you to that conclusion?  Many mTDI pumps are built from AAZ pumps.
Looks like an AHL to me with a mechanical pump and turbo to make installation into a rabbit easy.  I would wonder about the pump internals.
Andrew
its definitely a mk4 tdi with a mechanical pump, the later motors went to a chain driven oil pump, and the waterpump housing built into the block.  but the mk1 motor mounts don't bolt up to these blocks i wonder what they used to motor mounts.  and also the pump is slanted weird on the newer motors
Reply #6December 16, 2008, 04:40:57 pm
Powered by Spearco
  • 1203
« Reply #6 on: December 16, 2008, 04:40:57 pm »
Pass. side motor mount is a gas Rabbit mount modified.
The pump internals are unknown.
I thought that an mtdi pump on a MK4 would need a two piece pump pully so that you could adjust timing?
'13 Golf R:. Tuned
'98 Puch G320
Reply #7December 16, 2008, 05:08:26 pm
Quantum TD
  • 1195
« Reply #7 on: December 16, 2008, 05:08:26 pm »
Looks like and ALH mTDI to me. Not being from Europe, I can't speculate ebyond that, since there were some funky configuations all over Europe. But if you're in the US, then yes, ALH with and AAZ mechaincal (mTDI?) pump.
Reply #8December 16, 2008, 05:29:42 pm
rallydiesel
  • 1880
« Reply #8 on: December 16, 2008, 05:29:42 pm »
Looks promising. I wouldn't mind stumbling across a set-up like that.  :twisted:
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #9December 16, 2008, 06:49:04 pm
« Reply #9 on: December 16, 2008, 06:49:04 pm »
can i get a picture of the passenger motor mount?
Reply #10December 17, 2008, 10:24:33 am
nokivasara
  • 115
« Reply #10 on: December 17, 2008, 10:24:33 am »
THe engine looks like a ALH or AGR (my AGR looks like that, itīs a 90hp TDI with a wg-turbo, not VNT)
It looks like the IP needs to be rotated/tilted upwards towards the head, maybe thatīs whats wrong with it if it doesnīt run, the hardlines are in the wrong position  :?
Caddy 1.6N/A pushing 400 000km and going strong!
Reply #11December 17, 2008, 10:31:11 am
arb
« Reply #11 on: December 17, 2008, 10:31:11 am »
What's that on the oil cooler/filter flange ? Looks like a large oil separator.  Its also interesting to me how the IP is tilted.
Reply #12December 17, 2008, 10:45:03 am
foxracer1
  • 991
« Reply #12 on: December 17, 2008, 10:45:03 am »
The way the pumpis sittng looks just like a 99.5- later TDI MKIV but it just has a mechanical pump. I like it. How much do you want for it? ha i wish.
And the oil flange has the internal oil filter.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #13December 17, 2008, 11:08:21 am
arb
« Reply #13 on: December 17, 2008, 11:08:21 am »
Quote from: "foxracer1"
SWEET !! No dumping oil on the ground and less metal in the land fill. Its also nice to see the filter paper to look for metal flakes.
Reply #14December 17, 2008, 11:10:42 am
foxracer1
  • 991
« Reply #14 on: December 17, 2008, 11:10:42 am »
I may or may not have tossed the old one in the fire once done looking at it. Got heat from the old filter and oil. ha.
91 S10 305 TPI T56
