Author Topic: A2 Turbo boost  (Read 7485 times)
Reply #15December 14, 2008, 06:15:13 pm
dillenger1
  • 777
A2 Turbo boost
« Reply #15 on: December 14, 2008, 06:15:13 pm »
not so much with the t2 its similar to the ko3 in size i think.Instant boost.the unburnt fuel shouldnt be to bad,if its a subtle amount.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #16December 14, 2008, 06:20:04 pm
  • 3468
    • McScrubbins Body Wash
A2 Turbo boost
« Reply #16 on: December 14, 2008, 06:20:04 pm »
Ahh. I'm not very familiar with smaller turbos. I guess with a little one and turned up fuel it's like .. boost all the time? (almost boost at idle? :P )
I can't stop thinking about what that other fellow said... 40psi in 4th gear??? oh my ***?! My gauge doesn't even go to 40psi
Reply #17December 14, 2008, 06:35:52 pm
CaddyWVO
  • 37
A2 Turbo boost
« Reply #17 on: December 14, 2008, 06:35:52 pm »
I hope this works. Here is a photo:
[/img]<a><img></a>
1981 VW Caddy 1.9L TD AAZ
GTI wheels w/R-134AC
Bilstein struts & Neuspeed springs front
Monroe Sensimatics rear
Eurosport upper and lower stress bars
Suspension Technology Anti-Sway front
Reply #18December 14, 2008, 06:40:25 pm
CaddyWVO
  • 37
A2 Turbo boost
« Reply #18 on: December 14, 2008, 06:40:25 pm »
Here is an image of the turbo:
 (alt+p)
Reply #19December 14, 2008, 08:13:20 pm
Typrus
  • 93
A2 Turbo boost
« Reply #19 on: December 14, 2008, 08:13:20 pm »
Heh. We hit 3 bar in our 1Z with our first chipset. lol. 3bar=43PSI. Stock everything but nozzles, turbo, and ECU. LOL.
Now it'll get around 2 bar on a full throttle loaded romp. No issues so far. Still stock exhaust... Whether is sorta keeping us away from getting the rest of the system installed. In Mintern, CO. lol. Little bit of a drive in snow.
BTW, this is a ECU direct reading off of a VAG-COM. Thanks to Kerma for the 3 bar MAP. And everything else. lol
1995 Toyota Camry 2.2L 5-speed
1984 Toyota Tercel 4wd Wagon 1986 "           "           "      "
1996 VW Passat TDI 1Z w/ KermaTDI Stage 3 kit
1999.5 F-250 7.3L Powerstroke
2002 Excursion 7.3L Powerstroke (Dads)
Reply #20December 14, 2008, 09:16:36 pm
cyrus #1
  • 360
A2 Turbo boost
« Reply #20 on: December 14, 2008, 09:16:36 pm »
Do you have any pictures of the serial # plaque.  That looks like a regular old garrett T3 to me.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #21December 15, 2008, 12:08:23 am
TurboJ
  • 661
A2 Turbo boost
« Reply #21 on: December 15, 2008, 12:08:23 am »
It's a T3.
If it was a T2, it would have water cooling connectors on the center, in addition to the oil feed connections seen in the picture.
Jetta II 1.6 TD 'Project 200'
Reply #22December 15, 2008, 03:06:59 am
dillenger1
  • 777
A2 Turbo boost
« Reply #22 on: December 15, 2008, 03:06:59 am »
the downpipe side looks almost rounded instead of square.The wastegate fitting on mk2/ t3 are threaded instead of nipples.
Reply #23December 15, 2008, 07:22:18 am
CaddyWVO
  • 37
A2 Turbo boost
« Reply #23 on: December 15, 2008, 07:22:18 am »
Here are some additional images:
Reply #24December 15, 2008, 07:35:14 am
A2 Turbo boost
« Reply #24 on: December 15, 2008, 07:35:14 am »
Quote from: "Smokey Eddy"
I can't stop thinking about what that other fellow said... 40psi in 4th gear??? oh my HECK?! My gauge doesn't even go to 40psi
Fixed it for ya Ed ^^^^^
Reply #25December 15, 2008, 08:06:07 am
GTD0023
  • 28
A2 Turbo boost
« Reply #25 on: December 15, 2008, 08:06:07 am »
from what i see in the pic, this is a Garrett airresearch T3 turbo.
same i have on me golf!
vw golf 1.8 16v, vw golf G60, now going diesel...
Reply #26December 15, 2008, 08:09:36 am
GTD0023
  • 28
A2 Turbo boost
« Reply #26 on: December 15, 2008, 08:09:36 am »
ooh yeah,
these babies can easily hit 35-40 psi with closed wastegate.
i know...  (blown Metal Headgasket)
lifts the head right from the block man!!!!
Reply #27December 15, 2008, 08:35:41 am
CaddyWVO
  • 37
A2 Turbo boost
« Reply #27 on: December 15, 2008, 08:35:41 am »
Hey Guys, Thanks for the help identifying my turbo.
So if I put a boost controller on this T3 what is your input for type and PSI?
The link posted earlier has several varieties (single & two stage, manual and electronic).
http://www.boostcontroller.com/index.php?category=35
Keep in mind that I understand that any setting over stock will be a significant increase in power but I don't want to blow any gaskets or cook food on the exhaust manifold and I really just want to increase the fuel economy (until I can afford to upgrade the FIP to include the aneroid).
 Comments please...   :wink:
Reply #28December 15, 2008, 09:06:34 am
stewardc
A2 Turbo boost
« Reply #28 on: December 15, 2008, 09:06:34 am »
I would go with a manual Turbo XS and set it at about 20psi for daily driving. Do you have ARP head studs ?
Reply #29December 15, 2008, 09:47:57 am
MJF
  • 581
A2 Turbo boost
« Reply #29 on: December 15, 2008, 09:47:57 am »
Quote from: "GTD0023"
ooh yeah,
Yeah, probably due extreme emp :roll: Closing wastegate is never a good thing to do.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
