Author Topic: Hood latch in the core support  (Read 3521 times)
November 24, 2008, 02:56:07 pm
Jet A
  • 125
« on: November 24, 2008, 02:56:07 pm »
My hood latch is busted so the cable no longer works. the hood will not go down to the locked postion, but will lock in the safety postion (partial up but still closed). I am guessing there is some sort of spring in there, but dont know what happened to it. Is there a replacment spring or an entire unit? if so, where to get one for a reasonable price?
also, where do you buy the replacment handle? everyone sells the cable, but no one sells the handle.
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #1November 24, 2008, 06:46:40 pm
duffer
  • 164
« Reply #1 on: November 24, 2008, 06:46:40 pm »
I think your best bet would be the junk yard.
   Failing that, www.altrom.com sells the handle.
   It's Part #191 823 533.
Reply #2November 25, 2008, 12:46:41 am
  • 2932
« Reply #2 on: November 25, 2008, 12:46:41 am »
I used a handle off a MK2 Jetta for my Rabbit,... cut some of the end off and used the cable too.
 Maybe your latch just needs a spring, they rust out and fall off... I don't have a picture of one handy,... but it should be available at the hardware store.
