Author Topic: NA engines, ip's, other bits, tdi, and other stuff too  (Read 4351 times)
November 23, 2008, 07:49:49 pm
fuslit
  • 118
« on: November 23, 2008, 07:49:49 pm »
ok, I'd like to clear some space in my garage so I thought the best way to get it would be selling some engines that have congregated in my garage.
I have no idea if anyone here would be interested in full engines but figured I'd post up here before I tear them down to sell off piece by piece or work on rebuilding then sell.
Prices:
NA diesel:
1.6 na long block - 300 (oil pan to valve cover) True long block, no IP, etc.
1.6 Injection pump - 75
NA diesel lines - 20 per set
1.5 na long blocks - Haven't figured out the 1.5 stuff as it's potentially spoken for, but money talks so if your interested, make an offer.
http://en.wikipedia.org/wiki/List_of_discontinued_Volkswagen_Group_diesel_engines
NA Engine pics
Engine one: ME(?) 004 977 *
Engine two: ck 182 427
Engine three: ME 003 278 *
Engine four: CK 512 181
larger pics can be found here
http://fuslit.org/photo_gallery/index.php?album=misc/car/for_sale/20081123_engines/
engine four ran until I took it out of my rabbit because I was young and stupid and it didn't start correctly (was glow plugs, head gasket, who knows I yanked it and put a new used one in it's place...) I'd go through it and rebuild though. I was just pointing that out so you knew it didn't snap a timing belt.
TDI: I picked up as a potential rebuild but decided that I'd use some of it on my TD swap (serp belt swap as well as some other bits) when I'm done I'll put what I don't use up for sale as well.
Current tdi things up for grabs:
Parts of a 1.9 1Z tdi engine (long block, no IP, turbo, etc)
head - 300 (head, cam, valve cover)
injectors - 125
pistons - 55 each (3 good)
rods - ?
crank - 200
block - 60 (bare block, most likely needs bored over one piston melted from overheating)Currently the block is together (well bare block, crank minus the one rod and piston.)
Oil Pan - ?
I do have two TD motors which are potentially spoken for, I'll update the thread in regards to them, and try to get some pics of the TDI stuff.
I'll add more parts to the thread as I get time
-Todd
'81 rabbit 4dr 1.6TD [project]
'98 jetta tdi [daily]
Reply #1November 24, 2008, 11:04:49 am
blkboostedtruck
  • 1535
« Reply #1 on: November 24, 2008, 11:04:49 am »
Hi,
 i have an odd request! i need a block breather plate from a 1.5 for my breather box upgrade on my 1.9TD do you feel like parting or trading for just a block off plate?
well let me know?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2November 26, 2008, 05:51:28 am
fuslit
  • 118
« Reply #2 on: November 26, 2008, 05:51:28 am »
Quote from: "blkboostedtruck"
Hi,
well let me know?
Duane
I'll check to see if I've got a spare around and let you know
-T
Reply #3December 13, 2008, 09:03:25 am
fuslit
  • 118
« Reply #3 on: December 13, 2008, 09:03:25 am »
Quote from: "fuslit"
Hi,
well let me know?
Duane
-T
I don't have a spare sorry,
I've posted the engines up on a local CR.
-T
Reply #4December 14, 2008, 04:19:40 pm
akcummins
intermediate shaft pully
« Reply #4 on: December 14, 2008, 04:19:40 pm »
Would you happen to have an intermediate shaft pully for and 86 golf? It is the pulley with the channels on the side and I believe my broken ones part number is 068115021 B -Thanks
