Author Topic: No cruise control  (Read 4685 times)
November 19, 2008, 06:05:29 pm
DAKOTAKIDD
  • 114
No cruise control
« on: November 19, 2008, 06:05:29 pm »
Hey guys,
I am brand new to diesels and this kinda cruise control set up.  Any who..Mine does not work.  When I select the cruise to on, then hit set nothing happens.  From my research on here, this is a vacuum operated system.  The linkage on the fuel pump is connected.
Where should I start.
Sorry for the newb post
My car is a 91 Jetta turbo diesel 1.6l
Cheers
Chad
Reply #1November 20, 2008, 05:23:24 am
No cruise control
« Reply #1 on: November 20, 2008, 05:23:24 am »
check fuses first.
also, the vacuum actuator can rot away so that it can't move the accelerator.  you could fix that with a tire patch kit or something.  if you don't see any obvious cracks, then you could hook up a vacuum gauge to the line going to the actuator, and checking it as you drive and use the cruise.  that way you'll know if its the actuator or subsequent hose going to it.
if its not a vacuum leak, it could be the unit itself... or a simple wiring issue...
Reply #2November 20, 2008, 10:11:09 am
DAKOTAKIDD
  • 114
No cruise control
« Reply #2 on: November 20, 2008, 10:11:09 am »
Hey thx for the reply.. As I have no manual at all but one is ordered, wher are the fuses for CC located.  I check quickly under the dash but nothing said cruise control.  Is there somewhere else to look for fuses?
I will also get a vacuum gauge and see if I am getting vacuum.
Thx
C
Reply #3November 20, 2008, 10:25:57 am
No cruise control
« Reply #3 on: November 20, 2008, 10:25:57 am »
i found that most of the time it's either the vac switches/ vents under the dash on the brake and clutch peddles OR the vac pump under the hook on the drivers side frame rail died.
The wire off the back of the speedo fell off on my car  :oops:
Once that was hooked up it worked but kept shutting off, ended up the vac switch on the brake peddle was adjust to far away from the peddle.
Anyway, once you get your Bentley there is a good section in there with the instructions to test it out.
Reply #4November 20, 2008, 12:33:11 pm
JT Turbo
  • 18
No cruise control
« Reply #4 on: November 20, 2008, 12:33:11 pm »
Quote from: "zukgod1"
My cruise control doesn't work either, and after following the Bentley troubleshooting guide, it all checked out except that the speed sensor resistance (which is attached to the backside of the speedometer) is quite a bit higher than what Bentley says it should be, so I suspect it's tired.  Gasser speed sensors fit, but are different than diesel sensors. I'm still looking for the right replacement sensor, so I haven't been able to replace mine to verify that truly is my issue.  You'll need a mulitmeter to do the troubleshooting.
FYI - the cruise control brain is an aluminium box about the size of a cigarette pack mounted on the backside of the center console.
John
'91 Jetta TD Wolfsburg
'72 Datsun 510 wagon
'95 Isuzu Rodeo 4WD
Reply #5November 29, 2008, 08:22:58 pm
Settings
  • 52
    Hudson, QC
No cruise control
« Reply #5 on: November 29, 2008, 08:22:58 pm »
This summer my cruise control worked intermittently and eventually stopped working all together.
I poked around at a few things, but it ended up being the switch itself. I popped it off, cleaned it up a bit and now it works normally again.
Costs you nothing more than 5 minutes of your time to check it.
1993 AAZ Jetta ~280k
Reply #6December 01, 2008, 08:27:44 am
No cruise control
« Reply #6 on: December 01, 2008, 08:27:44 am »
my switch has been starting to act up but I couldn't see a way to take it apart. I'm all about taking stuff apart but I need to be able to make it usable again. Does the stalk just snap together?
Reply #7December 01, 2008, 11:42:48 am
Settings
  • 52
    Hudson, QC
No cruise control
« Reply #7 on: December 01, 2008, 11:42:48 am »
Yeah, I just popped mine off with a screwdriver.
Inspiration from this posting on TDIclub (scroll past the VAGCOM screen shots)
http://forums.tdiclub.com/showthread.php?p=825571
Mine looks a little different both inside and out, but essentially the same.
jer
Reply #8December 01, 2008, 11:52:39 am
No cruise control
« Reply #8 on: December 01, 2008, 11:52:39 am »
Well damn!
Thanks, I hope that takes care of my issues as well.
Reply #9December 01, 2008, 08:14:33 pm
No cruise control
« Reply #9 on: December 01, 2008, 08:14:33 pm »
I stopped at Checker on the way home, grabbed a can of contact cleaner. popped off the switch (broke it ) sprayed cleaner in there while pushing buttons. Drove home and it seems to be MUCH better now.
Thanks for the tip!
