Author Topic: K03 to VNT swap  (Read 7175 times)
November 19, 2008, 03:26:48 pm
blackdogvan
  • 574
K03 to VNT swap
« on: November 19, 2008, 03:26:48 pm »
Hi crew,
I am working towards a VNT install on my AAZ powered van. I have a sweet K03 but with 99.9% of my driving below 3500rpm I think a VNT15 would be a better fit. I only run 15lbs but having that 15lbs at a significantly lower rpm is the goal. Is it possible to mount a VNT15 core and compressor onto a K03 turbine end or is there a VNT15 model that will bolt directly to my mani? Keeping the wastegate appeals to me in case of boost spikes. I know whats required for the VNT control so that does not worry me for the project thanks to the Tintin/Libby/Jimfoo posts.
I've read through a few of the VNT threads but couldn't see this info...
1991 Vanagon 1.9 mTDI
Reply #1November 19, 2008, 06:10:21 pm
dillenger1
  • 777
K03 to VNT swap
« Reply #1 on: November 19, 2008, 06:10:21 pm »
the vnt's "turbine is what makes it a VNT.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2November 19, 2008, 08:26:39 pm
blackdogvan
  • 574
K03 to VNT swap
« Reply #2 on: November 19, 2008, 08:26:39 pm »
Thanks Andrew, the info's much appreciated! It was the european vnt separate turbine housing i was missing.
I meant the turbine end of the vnt turbo fitting into the turbine housing of the k03. In hind sight if it was that easy everyone here would have done it!
Reply #3November 19, 2008, 11:44:00 pm
rabbitman
  • 2788
K03 to VNT swap
« Reply #3 on: November 19, 2008, 11:44:00 pm »
I bought one with the separate mani on ebay last summer, didn't know it was anything special. I think I paid about $160. Someone must've snuck one into the US haha.
Reply #4November 20, 2008, 09:14:25 am
blackdogvan
  • 574
K03 to VNT swap
« Reply #4 on: November 20, 2008, 09:14:25 am »
I wonder if there is a source over there for the turbine housings only.
Reply #5November 20, 2008, 12:39:08 pm
rabbitman
  • 2788
K03 to VNT swap
« Reply #5 on: November 20, 2008, 12:39:08 pm »
This guy might have something you could use, not VNT but might work fine.
http://search.stores.ebay.com/epartsgogo_turbocharger_W0QQfciZQ2d1QQfclZ3QQfsnZepartsgogoQQfsooZ1QQfsopZ1QQsaselZ689909248QQsofpZ0
Don't know if they're junk or what but they sure are cheap enough.
Reply #6November 21, 2008, 09:11:25 am
blackdogvan
  • 574
K03 to VNT swap
« Reply #6 on: November 21, 2008, 09:11:25 am »
Ya, the K03 does spool nice at low rpm & can hold 15psi as long as the aaz likes to rev, which isn't too high anyway. I think its as close to a lagless wastegated turbo as you can find. I like low end grunt over screaming rpm, guess thats why I dislike 2 stroke jimmys.
