Author Topic: Engine oil in my LDA diaphragm  (Read 5328 times)
November 10, 2008, 05:06:54 am
molgrips
  • 134
« on: November 10, 2008, 05:06:54 am »
Oil's come through the hose that leads from the turbo to the LDA.  Not a lot, a few ml probably.  Is that bad?
1994 Passat 1.9 TD Estate, 180k miles, running on veg oil
Reply #1November 10, 2008, 08:18:58 am
molgrips
  • 134
« Reply #1 on: November 10, 2008, 08:18:58 am »
Hmm.
 - Engine doesn't consume oil, and idle is even, so I thought rings etc were ok
 - Turbo makes a slight whine when it spools up, can't hear it when driving - I thought that was normal
 - Lots of smoke and oily crap, and a fair bit of steam seems to be circulating around the crankcase venting system.. I found this out when I broke the hockey puck thing on top of the engine and had to bodge it back together...
So my money's on the crankcase problem :)  Maybe I'll try replacing the hockey puck.  What else could cause trouble with the crankcase vent?  I thought it was just a hose that looped back to the rocker cover.
Reply #2November 10, 2008, 09:25:52 am
« Reply #2 on: November 10, 2008, 09:25:52 am »
Has it been along time sense you have looked in there?
I've taken a few apart that had some oil in there but they hadn't been taken apart for YEARS so I attributed it to condensation. As in the oil vapor goes up that small tube to the LDA then condenses there.
Reply #3November 10, 2008, 09:28:32 am
« Reply #3 on: November 10, 2008, 09:28:32 am »
Quote from: "molgrips"
It's function is to maintain positive pressure in the engine to help the seals seal, and to avoid dirt from being sucked into the engine.
Reply #4November 10, 2008, 10:19:10 am
molgrips
  • 134
« Reply #4 on: November 10, 2008, 10:19:10 am »
It was the first ever time I'd looked in there, possibly the first time ever anyone'd opened it.  The oil did look perhaps a shade lighter than the engine oil currently is, but that's hard to tell.  I should probly check again in a few thousand miles...
Reply #5November 10, 2008, 03:48:04 pm
« Reply #5 on: November 10, 2008, 03:48:04 pm »
Check it after 100 miles, if the turbo is bad you'll know soon.
Reply #6November 10, 2008, 06:59:55 pm
dillenger1
  • 777
« Reply #6 on: November 10, 2008, 06:59:55 pm »
they are oiled at the factory i think.I had one with oil in the fuel pins bore.Theres no air flow through there,just pressure.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #7November 11, 2008, 01:47:45 am
molgrips
  • 134
« Reply #7 on: November 11, 2008, 01:47:45 am »
Thanks guys.  Will check on it later.
