Author Topic: AAZ into mk1 question  (Read 2045 times)
November 08, 2008, 04:46:32 pm
ilikevwdiesel
  • 1202
« on: November 08, 2008, 04:46:32 pm »
Do the large pin AAZ injection pumps bolt right onto the 1.6 injection pump/engine mount bracket found on mk 1 cars? That is if you are installing an AAZ into a rabbit does the mk 1 bracket work fine on the AAZ?  :?
My Bio
Reply #1November 08, 2008, 05:45:28 pm
ilikevwdiesel
  • 1202
« Reply #1 on: November 08, 2008, 05:45:28 pm »
The reason I ask is I just installed a 97 AAZ into my Caddy, the pump has the pulley held on by 3 bolts. Now I'm having trouble with the IP.  I can get a good deal on the earlier AAZ pump that uses the big pin to lock it but I don't know the deal with this setup as far as the bracket and the timing cover set. I modded the AAZ cover and used a gasser mount on the present setup, but how does it all work out on big pin pumps? I have plenty of 1.6 IP/engine mount brackets. And one more thing: will the serp belt setup work when you use the mk1 mount bracket?
My Bio
Reply #2November 09, 2008, 06:37:00 am
« Reply #2 on: November 09, 2008, 06:37:00 am »
Check the FAQ for info on the mk1 serp setup. I had to cut a piece off the bracket
I think you can just use a 1.6 bracket with the single piece pulley AAZ pumps
Reply #3November 09, 2008, 06:51:13 am
ilikevwdiesel
  • 1202
« Reply #3 on: November 09, 2008, 06:51:13 am »
thanks for the info. I wonder if the bracket won't have to be cut on an AAZ where the block is taller?
My Bio
Reply #4November 09, 2008, 12:27:24 pm
« Reply #4 on: November 09, 2008, 12:27:24 pm »
It's possible. Mount it up and you'll see right away
