Author Topic: Replacing rear brake hoses  (Read 3864 times)
November 06, 2008, 05:14:54 pm
clbanman
  • 705
    Cambridge, Ontario
« on: November 06, 2008, 05:14:54 pm »
Is there some trick to removing these hoses (at the rear axle) from the brackets on the frame?  I don't know if I'm missing something or if it's just the 17 years of rust on the parts that are making them seem hard to get out.  The brackets on the frame that they go through are actually bending without the hose ends coming out.
Calvin
91 VW Golf 1.6NA 5spd
Reply #1November 06, 2008, 06:54:02 pm
blkboostedtruck
  • 1535
« Reply #1 on: November 06, 2008, 06:54:02 pm »
17 years of rust! if your replacing the rubber hoses just add some heat!
you will burn the rubber but oh well! your replacing them anyways! and the heat wont ruin the steel unless you add too much heat!
but if your steel lines look pretty bad i would just replace them also!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2November 06, 2008, 11:21:59 pm
  • 2932
« Reply #2 on: November 06, 2008, 11:21:59 pm »
Not sure what car you are working on,... no car in your sig or mentioned in your post.
Reply #3November 07, 2008, 02:27:27 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #3 on: November 07, 2008, 02:27:27 am »
91 Golf.
Calvin
Reply #4November 07, 2008, 07:41:41 am
  • 1739
« Reply #4 on: November 07, 2008, 07:41:41 am »
It helps to hold the 11mm fitting on the hard line. However because it's rusted on there, cut the rubber hose [it will burst when heated] get a torch or propane torch and heat the fitting until it gets red. once red soak it fast with cold water preferably a hose . it then should come loose
Reply #5November 07, 2008, 07:50:36 am
« Reply #5 on: November 07, 2008, 07:50:36 am »
Quote from: "the caveman"
alternatively you can use rust check's freeze can to break rusted things free. you can find it at cdn tire
