Author Topic: Rear wiper problems  (Read 4649 times)
November 05, 2008, 07:16:18 pm
TOW'D
  • 100
Rear wiper problems
« on: November 05, 2008, 07:16:18 pm »
Howdy gang,
 The wires are attached to the rear wiper but no power
first off I'm not sure where the switch to turn it on is.
 I get the washer to work by pushing in on the wiper switch
anybody happen to know if there is a relay (has to be one, correct)?
  its "Bosch"number would be help full
thanks
hank
'85 Golf 4door diesel
way too many projects not much time
Reply #1November 05, 2008, 08:59:49 pm
Rear wiper problems
« Reply #1 on: November 05, 2008, 08:59:49 pm »
those motors have a tendency to burn out... or maybe its just corrosion screwing everything up?
Reply #2November 05, 2008, 09:43:17 pm
TOW'D
  • 100
Rear wiper problems
« Reply #2 on: November 05, 2008, 09:43:17 pm »
I'll hot wire the wiper to see if it works
hank
Reply #3November 06, 2008, 02:30:23 am
clbanman
  • 705
    Cambridge, Ontario
Rear wiper problems
« Reply #3 on: November 06, 2008, 02:30:23 am »
I think it's supposed to turn on by pulling back on the wiper switch, can't remember exactly because mine doesn't work.
Calvin
91 VW Golf 1.6NA 5spd
Reply #4November 06, 2008, 09:04:17 am
Dakotakid
  • 1240
Rear wiper problems
« Reply #4 on: November 06, 2008, 09:04:17 am »
It has been awhile since I had one that still works. As I recall, to start it you push downward (toward dash) with turn signal stalk to initiate movement. Then push downward again rather quickly while the rear wiper is still on motion to shut it off.....at least THAT is what I used to do in the ol' '85 Golf model.
My '86 was turned on once and put out smoke (as per JT's explanation above) and then went dormant.
Reply #5November 06, 2008, 09:35:52 am
duffer
  • 164
Rear wiper problems
« Reply #5 on: November 06, 2008, 09:35:52 am »
Sometimes those 22-year-old wires
   get brittle and break with the opening
   and closing of the hatch.
Reply #6November 06, 2008, 01:28:24 pm
Dakotakid
  • 1240
Rear wiper problems
« Reply #6 on: November 06, 2008, 01:28:24 pm »
I meant the wiper lever NOT the turn signal one.
Reply #7November 07, 2008, 07:15:21 pm
TOW'D
  • 100
Rear wiper problems
« Reply #7 on: November 07, 2008, 07:15:21 pm »
I can make the rear wiper work by hot wiring it.
pulling back on the wiper switch arm I get the front washer to spray and push it in makes the rear washer work
still haven't found the off and on
It will be me and the Bentley vs. the rear wiper tomorrow
hank
Reply #8November 09, 2008, 06:48:57 am
TOW'D
  • 100
Rear wiper problems
« Reply #8 on: November 09, 2008, 06:48:57 am »
Just like I figured there is a missing relay
I can hot wire the rear wiper by jumping a couple of the plugs on the relay board.
Anybody have a used relay for sale ?
or even the parts number sure would be big help
still haven't found the off and on switch
thankx
hank
