Author Topic: Oil coolers?  (Read 6444 times)
Reply #30November 06, 2008, 04:14:36 pm
Jettagli16v
  • 344
Oil coolers?
« Reply #30 on: November 06, 2008, 04:14:36 pm »
http://www.eurosportacc.com/eurosport_oil_cooler_oilcooler_kit_mocal.htm
This is EuroSport and their oil cooler selection.
They provide a Mocal thermostatic sandwich plate, which installs after your stock "Oil" - "Coolant" Oil cooler,
and adds a thermostat so it only runs it thru the cooler (The oil-air one, that is..) after it is up to temp..
The Cooler pictured that someone asked about is an aftermarket cooler to fit the front bumper in a 70's 911 RS. The cost of these coolers is insane.
Go generic! Buy the thermo plate from EuroSport and buy a cheap cooler and get the best of all!
Reply #31November 06, 2008, 04:54:06 pm
blkboostedtruck
  • 1535
Oil coolers?
« Reply #31 on: November 06, 2008, 04:54:06 pm »
Quote from: "Smokey Eddy"
Thank you Mr.Harry Mann for correcting me and that piece of info
please show me yours Ed!
Oh my, what is this turning into Duane?
Sorry for the poor picture i have no room in my garage. I made those tables out of scrap wood and particle board leaving a chair between them and the car for me to stand on to take pictures. The openings are on the "top" in this picture. Look how caked it is! I can only see through it in a few places. There is a minor ding in the bottom causing some mangled fins but it doesn't appear to effect the lowest passageway. The openings for the hoses are as follows : one on the top left of the picture and one out the very end. So it's different than the one i posted in that respect but the outlets are still at the same end. Just 90 degrees from each other.
just a oil cooler all it's doing! but it has to fit inside my bumper !
can that one fitting that at 90 be changed to be strait like the one on the right? my line's are gonne run through my bumper and through the bumper brackets and then through the core support! i want it hidden!
the bumper will have scoops cut and welded underneath for air flow!
i been conjuring up this for years till you posted that pic. and knew thats the one i been looking for! i looked on flea-bay and still nothing like that one you have?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
