Author Topic: Oil coolers?  (Read 6453 times)
Reply #15November 06, 2008, 06:24:29 am
TurboJ
  • 661
Oil coolers?
« Reply #15 on: November 06, 2008, 06:24:29 am »
Here's a link that shows a thermostat-equipped sandwhich plate:
http://www.racerpartswholesale.com/product/2972/Mocal_Sandwich_Plate
You just put it where the water/oil thingy originally was.
Jetta II 1.6 TD 'Project 200'
Reply #16November 06, 2008, 12:25:29 pm
  • 3468
    • McScrubbins Body Wash
Oil coolers?
« Reply #16 on: November 06, 2008, 12:25:29 pm »
aw i wish that wasn't 100 bucks :(
maybe i could find one at a scrap yard! there are tons of wrecked ricers there! but none that would mount a filter that large though?
or is that sandwich thing pretty universal?
Reply #17November 06, 2008, 01:44:07 pm
Oil coolers?
« Reply #17 on: November 06, 2008, 01:44:07 pm »
Saab Turbo cars have Engine oil coolers with those thermostatic plates.
I got mine from a PnP for like $25.00.
Reply #18November 06, 2008, 01:48:54 pm
blkboostedtruck
  • 1535
Oil coolers?
« Reply #18 on: November 06, 2008, 01:48:54 pm »
Quote from: "Smokey Eddy"
Quote from: "zukgod1"
You need to eliminate the factory one and get a sandwich adapter to get the fittings needed to run to the cooler.
You can NOT pull it from the head or even from the oil filter mount (top).
It needs to come from between the filter and the mount.
Is it hard to do?
Duane, my cooler needs a solvent bath. It's filled with oil and who knows what all else. I got it for free. I don't even know if it holds oil.
I think i will need a cooler with my build so ...
But hey, if you throw me an offer. I'll let you know if it leaks or not as soon as i test it. Pm me with an offer for it if it were to work.
smoke ,
if it looks just like that one! i'll give you 20bucks +ship for it?
i have another  one that just uses a rubber hose and hose clamps!
but i want to use my fittings that i have with the sandwich plate and the stainless braided hose i have! we can do a partial trade or something with the one i got?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #19November 06, 2008, 02:11:13 pm
Oil coolers?
« Reply #19 on: November 06, 2008, 02:11:13 pm »
Turbo Volvos as well... direct bolt-on, comes with nice long hoses, and is usually dirt cheap at PnP... I grab the thermostat plates if nothing else and they usually give me them for free if there is other stuff in the pile they already know the codes for...  :wink:
Reply #20November 06, 2008, 02:23:44 pm
  • 3468
Oil coolers?
« Reply #20 on: November 06, 2008, 02:23:44 pm »
Sorry Duane, for 20$ I'm going to keep it.
I need one anyways.
It was a real fluke that i got it.
I'm not sure what you guys are talkign about with the volvos and saabs i wish my local junk yard had more exotic cars. Its like 90% neons and corolla's.
Reply #21November 06, 2008, 02:54:40 pm
blkboostedtruck
  • 1535
Oil coolers?
« Reply #21 on: November 06, 2008, 02:54:40 pm »
I need one anyways.
well you said make an offer? what you have in mind ?
my earls cooler i don't like because the in/out is not on the same side! i want whats like in that pic. you posted! c;mon work with me here?
just one of those fittings are 25bucks! i've got 350bucks just in my fittings,braided hose,thermal sandwich plate! but just have not found the right cooler for my application ?
Duane
'66 variant 1500S
Reply #22November 06, 2008, 03:04:20 pm
HarryMann
  • 170
Oil coolers?
« Reply #22 on: November 06, 2008, 03:04:20 pm »
aw i wish that wasn't 100 bucks Sad
For once we are better off...
Mocal SP1T
About £40 here, in fact the non-thermo one (SP1) I have fitted was £25...
Can send one over... if you wanna Paypal us + shipping
Reply #23November 06, 2008, 03:09:08 pm
  • 3468
Oil coolers?
« Reply #23 on: November 06, 2008, 03:09:08 pm »
Quote from: "blkboostedtruck"
I need one anyways.
Duane
That really sucks.
how did you accumulate that insane cost in fittings? that's a lot of money.
Again, i don't even know if it holds oil.
I'll get a pic up in a bit here so you can see. It's not exactly that  cooler but very similar
Reply #24November 06, 2008, 03:22:28 pm
HarryMann
  • 170
Oil coolers?
« Reply #24 on: November 06, 2008, 03:22:28 pm »
..isn't eBay full of them??
PS> Easy to get 'done' on fittings by 'posh' shops... they don't seem to realise 80 psi would be max, not 800bar !!!
Reply #25November 06, 2008, 03:31:35 pm
  • 3468
Oil coolers?
« Reply #25 on: November 06, 2008, 03:31:35 pm »
800 bar!!!!!!
yeah i don't think the fittings need to be that high end. our pumps run at 2bar oil pressure i believe.
Reply #26November 06, 2008, 03:37:37 pm
blkboostedtruck
  • 1535
Oil coolers?
« Reply #26 on: November 06, 2008, 03:37:37 pm »
well i'm sure you heard the term a fool and his money will soon depart!
as i walk in a local speed shop here in town!
retail on them is expensive!
if it leaks and the hole is accessible i can weld it !
but yea i'll look on flea-bay again i never found what i wanted till i seen that pic. of one Eddy posted
Duane
please show me yours Ed!
'66 variant 1500S
Reply #27November 06, 2008, 03:42:46 pm
HarryMann
  • 170
Oil coolers?
« Reply #27 on: November 06, 2008, 03:42:46 pm »
Used unreinforced hoses on mine, cheap, cheerful but limited bend radius before they kink, pump up nicely when the engine starts though, sort of acts like an accumulator  :)
4 bar about (60 psi) and if pickup by-pass valve jams (not un-common) about 120~140 psi
Reply #28November 06, 2008, 04:05:23 pm
  • 3468
Oil coolers?
« Reply #28 on: November 06, 2008, 04:05:23 pm »
Thank you Mr.Harry Mann for correcting me and that piece of info
Oh my, what is this turning into Duane?
Sorry for the poor picture i have no room in my garage. I made those tables out of scrap wood and particle board leaving a chair between them and the car for me to stand on to take pictures. The openings are on the "top" in this picture. Look how caked it is! I can only see through it in a few places. There is a minor ding in the bottom causing some mangled fins but it doesn't appear to effect the lowest passageway. The openings for the hoses are as follows : one on the top left of the picture and one out the very end. So it's different than the one i posted in that respect but the outlets are still at the same end. Just 90 degrees from each other.
Reply #29November 06, 2008, 04:14:18 pm
monomer
  • 414
Oil coolers?
« Reply #29 on: November 06, 2008, 04:14:18 pm »
What about connecting it with a bypass oil filter (of better micron standards) and do away with the stock setup completely?
I know some of the benzes do....
I just dont know about flow ratings/ pressure.
www.michiganvw.org
