Author Topic: Easiest M-TDI  (Read 4242 times)
November 03, 2008, 10:21:51 pm
darkghost
  • 17
Easiest M-TDI
« on: November 03, 2008, 10:21:51 pm »
wWhat block and pump combo is going to be the easiest m-tdi conversion out there.a I have a suzuki samurai I want to put diesel power in and well I figure go TDI instead of IDI you guys are the gurus so can ya give a guy a hand thnx Jim Morrison
Dont use more force just get a bigger hammer
Reply #1November 04, 2008, 05:54:21 am
Easiest M-TDI
« Reply #1 on: November 04, 2008, 05:54:21 am »
Where are you? That can have a big effect on the answer.
Reply #2November 04, 2008, 06:05:11 am
Justin
  • 455
Easiest M-TDI
« Reply #2 on: November 04, 2008, 06:05:11 am »
the answer is its not easy, you should just give up now and sell your samuri to me very cheap and then i will show you how hard it is. Just kidding, its pretty easy to do once you get the Pump built for it. unless set up to work on these pumps you should leave it to a shop so that you dont mess it up like I did. other than that it all bolts together,
the early TDI's are the easiest since they bolt up like an IDI with the engine brackets I believe the years are 96-99, mid 99 they changed over though to the block integrated water pump and thats when things can get a little tricky
but seriously if you have another samuria and are in the midwest region let me know as i am looking for one.
good luck,
jkeiffer
www.archeryprostaffmi.com
Reply #3November 04, 2008, 06:34:49 am
darkghost
  • 17
Easiest M-TDI
« Reply #3 on: November 04, 2008, 06:34:49 am »
I live in B.C. and well if you want a samurai its not hard to find them up here. So just out of curiousity what block codes should I be looking for and just to ask the bolt patterns on everything from the 1.5 idi to the 1.9 tdi are the same are they not. Thanx again Jim Morrison
Reply #4November 04, 2008, 06:55:05 am
Easiest M-TDI
« Reply #4 on: November 04, 2008, 06:55:05 am »
you have a cool name!  8)
look for a TDI 1Z/AHU or do like jimfoo and take an AAZ, install TDI pistons, and a TDI head and off you go!  :wink:
Reply #5November 04, 2008, 09:42:14 am
Easiest M-TDI
« Reply #5 on: November 04, 2008, 09:42:14 am »
AAZ is a harder route in that it is not easy to find spare TDI valve covers or lines, but 1Z/AHU's were more scarce down in the states I think.
Reply #6November 04, 2008, 10:04:55 am
Easiest M-TDI
« Reply #6 on: November 04, 2008, 10:04:55 am »
Quote from: "jimfoo"
true.. i bought a 1Z longblock for $1200 that came from europe.  it was in great shape.  pistons still within spec, installed new goetze rings with total seal groove machined in with their sealing rings.  all new bearings installed etc.  the head got all new lifters, shaved smooth... i can't wait to get it running!!!!  all the work to the motor cost me about $600-ish, including the rings, bearings, and work.  the rings were quite costly due to the canadian dollar, and customs charges etc.
longblock did not have a pump or turbo though... :( and those are big ticket items, especially on an mTDI (if you want it to run the way it was intended)
Reply #7November 04, 2008, 10:51:45 am
burnt_servo
  • 278
Easiest M-TDI
« Reply #7 on: November 04, 2008, 10:51:45 am »
just to give you another option ,
i helped my brother with a suzuki comversion , and we used a 1.6  turbo out of a '88 jetta , and built that motor up .
long story short the 1.6 , hopped up ,  makes way more power than the stock suzuki running gear can handle  , and he's rounding up  the needed toyota  parts to swap in next spring .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #8November 04, 2008, 04:55:32 pm
blkboostedtruck
  • 1535
Re: Easiest M-TDI
« Reply #8 on: November 04, 2008, 04:55:32 pm »
Quote from: "darkghost"
hey is this the same Jim that was selling nozzels on E-bay or do i have you mixed up with somebody else?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #9November 04, 2008, 08:15:17 pm
darkghost
  • 17
Easiest M-TDI
« Reply #9 on: November 04, 2008, 08:15:17 pm »
No I wasnt selling nozzles and as for the power of a M-TDI well I have all yota running gear thats why I was gonna go M-TDI I think the stock Zuki stuff is $#!# if you know what I mean so it sounds like an AHU or 1Z that I am looking for then with the pump what do I do just get Giles to do it or is there a DIY out there
