Author Topic: 84 VW Rabbit Timing Belt Tensioner  (Read 4074 times)
October 28, 2008, 01:28:52 pm
angelisapayne
« on: October 28, 2008, 01:28:52 pm »
I am in dire need of the stud that goes in the timing belt tensioner.  It is a 10/125 stud and nut and washer.  I lost mine and can't dind another one anywhere.  It is a stud with two pins attached at the top.  Please help if you can.
Thanks
Reply #1October 28, 2008, 01:52:07 pm
Re: 84 VW Rabbit Timing Belt Tensioner
« Reply #1 on: October 28, 2008, 01:52:07 pm »
Quote from: "angelisapayne"
Huh??
How can a stud have 2 pins attached to the top?
Are you thinking the 2 holes in the tensioner are for the stud?
That's where the tool goes to adjust the belt.
Reply #2October 28, 2008, 02:27:35 pm
angelisapayne
« Reply #2 on: October 28, 2008, 02:27:35 pm »
Ok, there is a stud that is suppose to run through the midlle hole and a nut and washer attaches to the other side.  That is the part I have lost.
Reply #3October 28, 2008, 02:58:18 pm
« Reply #3 on: October 28, 2008, 02:58:18 pm »
Ok now that makes sense..
I may have a stud but it may take a couple days to confirm.
Where are you located on this big Blue planet?
Reply #4October 28, 2008, 03:03:18 pm
angelisapayne
« Reply #4 on: October 28, 2008, 03:03:18 pm »
I am in Cookeville TN. 38501.  If you could goto autozone.com and look up part # 024-0985 that is the tensioner I have.  The stud I need goes in the middle, maybe this will help you more to see the pic.
Thanks a bunch!!!!!!!
Reply #5October 28, 2008, 11:06:32 pm
Quantum TD
  • 1195
« Reply #5 on: October 28, 2008, 11:06:32 pm »
You should be able to get the part from your local CarQuest dealer.
Reply #6October 29, 2008, 04:56:18 am
« Reply #6 on: October 29, 2008, 04:56:18 am »
The dealership also sells it for less then $5. All 3 pieces
