For Sale/Looking For
Parts for Sale/Wanted
84 VW Rabbit Timing Belt Tensioner
Topic: 84 VW Rabbit Timing Belt Tensioner (Read 4068 times)
October 28, 2008, 01:28:52 pm
angelisapayne
October 28, 2008, 01:28:52 pm »
I am in dire need of the stud that goes in the timing belt tensioner. It is a 10/125 stud and nut and washer. I lost mine and can't dind another one anywhere. It is a stud with two pins attached at the top. Please help if you can.
Thanks
October 28, 2008, 01:52:07 pm
Re: 84 VW Rabbit Timing Belt Tensioner
October 28, 2008, 01:52:07 pm »
Quote from: "angelisapayne"
Huh??
How can a stud have 2 pins attached to the top?
Are you thinking the 2 holes in the tensioner are for the stud?
That's where the tool goes to adjust the belt.
October 28, 2008, 02:27:35 pm
angelisapayne
October 28, 2008, 02:27:35 pm »
Ok, there is a stud that is suppose to run through the midlle hole and a nut and washer attaches to the other side. That is the part I have lost.
October 28, 2008, 02:58:18 pm
October 28, 2008, 02:58:18 pm »
Ok now that makes sense..
I may have a stud but it may take a couple days to confirm.
Where are you located on this big Blue planet?
October 28, 2008, 03:03:18 pm
angelisapayne
October 28, 2008, 03:03:18 pm »
I am in Cookeville TN. 38501. If you could goto autozone.com and look up part # 024-0985 that is the tensioner I have. The stud I need goes in the middle, maybe this will help you more to see the pic.
Thanks a bunch!!!!!!!
October 28, 2008, 11:06:32 pm
Quantum TD
October 28, 2008, 11:06:32 pm »
You should be able to get the part from your local CarQuest dealer.
October 29, 2008, 04:56:18 am
October 29, 2008, 04:56:18 am »
The dealership also sells it for less then $5. All 3 pieces
