Author Topic: Have a NEW Vac pump - need a cluster w/ tach  (Read 4772 times)
October 26, 2008, 04:01:54 pm
arb
« on: October 26, 2008, 04:01:54 pm »
OK, minor problem if I want to know how many miles I've driven and my MPG (GPS will give me speed) - The caravan trans speedo sending unit is of a different size than the mechanical VW connection...
So, I need to get a VW cluster with mechanical drive. I have a NEW extra vac pump I'd like to trade with someone for a VW cluster - Speedo and Tach. Any one interested ?
I don't care about the year as long as it works and uses a cable that will fit a 1982 5 speed
Reply #1October 26, 2008, 05:47:30 pm
blkboostedtruck
  • 1535
« Reply #1 on: October 26, 2008, 05:47:30 pm »
i have one that will fit a 82 but the tach is a gasser tach!
there were no clusters in diesel that year with a tach.
well let me know?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2October 26, 2008, 06:20:18 pm
arb
« Reply #2 on: October 26, 2008, 06:20:18 pm »
My engine is a 1982.5 but the car is a Dodge Caravan !!!  That's why I don't care about the year as long as the speedo drive cable will work with my 1982 trans. Someone should have a diesel cluster that would work...
http://vwdiesel.net/phpBB/viewtopic.php?t=15633
Reply #3October 26, 2008, 06:44:31 pm
blkboostedtruck
  • 1535
« Reply #3 on: October 26, 2008, 06:44:31 pm »
i know what you have there! and i have a 82 cluster w/ tach from gasser!
there are no diesel cluster's with a tach for that year!
this one will work but you will have to modify the tach to work with a diesel W signal and add a glow plug lite if you choose too?
your cable screws on to the back of the cluster or you have a slip on  style?
Duane
'66 variant 1500S
Reply #4October 26, 2008, 07:06:20 pm
arb
« Reply #4 on: October 26, 2008, 07:06:20 pm »
The trans did not come with a cable. I need a cable too.
Reply #5October 26, 2008, 07:44:25 pm
blkboostedtruck
  • 1535
« Reply #5 on: October 26, 2008, 07:44:25 pm »
Quote from: "arb"
i'm sure i got one too! screw on would be the best! if you end up short you can add a jetta oxy censer block and add another section of speedo cable if it ends up short to your dash!
Duane
'66 variant 1500S
Reply #6October 26, 2008, 09:00:00 pm
  • 2932
« Reply #6 on: October 26, 2008, 09:00:00 pm »
So, what kind of speed sensor is that? Doesn't have a cable?
 Ya know some of the MK3s had a speed sensor with no cable. Fit right in the 020 speedo hole. I wonder how well one of those would hook up to the stock cluster. If it would work that would save you rewiring a VW cluster into it.
Reply #7October 27, 2008, 05:56:53 am
arb
« Reply #7 on: October 27, 2008, 05:56:53 am »
My trans is a mechanical drive speedo - as seen in the photo. I need a diesel cluster that will work with my trans. Year not important.
