Author Topic: URGENT: AAZ conversion going horribly wrong... HELP!!!  (Read 4644 times)
October 21, 2008, 05:26:41 pm
LoneWolf
« on: October 21, 2008, 05:26:41 pm »
Ok, things are getting complicated, im using an AAZ block and head with my GTD ancillaries, turbo, manifolds etc, but i cant work out how to plump in the turbo oil feed.
 on the 1600 it goes to the sump, but i dont know where it goes on the 1900, and the water cooling on the turbo is nowhere to be found on my 1900
   HELP!!!!
Reply #1October 21, 2008, 05:48:18 pm
« Reply #1 on: October 21, 2008, 05:48:18 pm »
It sounds like you are actually talking about the oil drain. There is a hole in the back of the block behind cyl #2 that the oil drains into. Or swap on the 1.6 pan. The drain hose will probably need to be lengthned though
As for the water cooling, no idea. Use a non water cooled turbo
Reply #2October 21, 2008, 08:01:18 pm
blkboostedtruck
  • 1535
« Reply #2 on: October 21, 2008, 08:01:18 pm »
this pic. will give you an idea for water hook up! hope it helps?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3October 21, 2008, 08:54:01 pm
« Reply #3 on: October 21, 2008, 08:54:01 pm »
At a turbo shop I was at, I asked the guy about water cooled turbos and he said you don't have to plumb water to them. YMMV...
Reply #4October 22, 2008, 12:04:30 am
LoneWolf
« Reply #4 on: October 22, 2008, 12:04:30 am »
my 1600 has the water line plumbed in through a core-plug on the back of the engine, but where does it plumb in on the 1900?
Reply #5October 22, 2008, 01:34:34 am
MJF
  • 581
« Reply #5 on: October 22, 2008, 01:34:34 am »
Take the freeze plug from 1,6. 1.9 never had water cooled turbos.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #6October 23, 2008, 07:11:20 am
LoneWolf
« Reply #6 on: October 23, 2008, 07:11:20 am »
Crisis averted, ive got the oil and water plumbed in now, i used the heater matrix return pipe to plumb in the wat for the turbo, so hopefully all should be sorted now  :D
