Author Topic: Governor adjust  (Read 6402 times)
October 15, 2008, 05:11:14 pm
autoholic
Governor adjust
« on: October 15, 2008, 05:11:14 pm »
I have never messed with the governor adjustment. Are there gain's to be had there, can this  be a simple power increase? The pump I just did for my friend runs like a typical stock VW, it starts to cut fuel off around 2500 RPM (just guessing) and while I do not want it to rev to the moon, it would be great if he could have full fuel up higher in the revs. I thought I would inquire before messing with it, I'm sure there are folks here who could not resist playing with this adjustment!
I did the governor mod on my pump and it feels alot stronger. I left the actual governor setting where it was.
Reply #1October 15, 2008, 05:39:23 pm
dillenger1
  • 777
Governor adjust
« Reply #1 on: October 15, 2008, 05:39:23 pm »
did you preload it?You said you never messed with the governor. :?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #2October 15, 2008, 05:45:15 pm
autoholic
Governor adjust
« Reply #2 on: October 15, 2008, 05:45:15 pm »
Quote from: "dillenger1"
No, i don't think I did. I did the gov mod deal and put the shaft/nut adj back where it was originally. Same with my friends pump that does not have the gov mod. I'll search around for info on the preload- thanks for bringing it to my attn.
I tend to just dive right in, then learn about things I missed after!
Reply #3October 16, 2008, 08:12:08 am
Governor adjust
« Reply #3 on: October 16, 2008, 08:12:08 am »
There is no preload.
You do the gov mod and re install in the same place.
Reply #4October 16, 2008, 11:50:01 am
dillenger1
  • 777
Governor adjust
« Reply #4 on: October 16, 2008, 11:50:01 am »
I dont think you understand the governor mod.Its modifying the spring assembly on the throotle shaft.Its inside the pump.Are you taking about the accelerator stop screw?(threaded rod with two stop nuts)Did you open up your pump?
Reply #5October 16, 2008, 12:50:09 pm
Governor adjust
« Reply #5 on: October 16, 2008, 12:50:09 pm »
Yeah, I think youse guys are talking about apples and oranges.
My guess is that the OP is asking about tweaking the big screw that goes down the middle of the governor (counterweights) shaft... the one with the left-hand thread and the locknut.
Everyone else is talking about the so-called "governor mod"... shimming the various springs on the internal throttle linkage.
Or at least, that's my guess ??!!!
Reply #6October 16, 2008, 01:20:51 pm
autoholic
Governor adjust
« Reply #6 on: October 16, 2008, 01:20:51 pm »
I did the gov mod on my pump (washers on throttle arm linkage deal) and understand what it does , but my question is on the external adjustment , the threaded shaft with locknut at front of pump. I am just curious what others have experienced when playing with this adjustment.
Reply #7October 16, 2008, 09:43:07 pm
Governor adjust
« Reply #7 on: October 16, 2008, 09:43:07 pm »
Quote from: "autoholic"
That shaft is apparently the max engine speed setting for the governor.  It's reverse thread...  I think it's the "right" (Bosch) way to set maximum speed...
Reply #8October 17, 2008, 06:20:11 am
dillenger1
  • 777
Governor adjust
« Reply #8 on: October 17, 2008, 06:20:11 am »
I set my shaft to the top of the nut when rebuilding.they were completely flush when i started.Does that shaft govern the max speed,because its already set to go to 6000 rpm.
Reply #9January 01, 2009, 09:21:27 am
Tony2ltr
  • 53
Governor adjust
« Reply #9 on: January 01, 2009, 09:21:27 am »
When I turned this in too much, it richened up the fuel so much that the engine would not idle down after releasing the throttle, I would have to stall it down...
-Tony
92 Jetta Ecodzl/biodzl/WVO/meth-H2O turbspray
1969 Subaru 360 Sambar (converted to Electric)
1975 Chevy Cosworth Vega Turboed
1991 Toyota Pickup (megasquirted)
2004 POS Honda Civic (I'll never buy another)
2 cylinder Lister Petter diesel CO-Gen unit
Reply #10January 03, 2009, 02:32:03 pm
Jettagli16v
  • 344
Governor adjust
« Reply #10 on: January 03, 2009, 02:32:03 pm »
>Describing fuel (or smoke) screw on top of LDA...
>Ditto...
>Seems like you are describing the physical stops for the throttle action.
Bentley Manual says with the car in neutral, slowly increase the throttle until you get no more revs. If it goes to 5000, you are properly set, otherwise, adjust more or less as needed.
-Brad
Reply #11January 03, 2009, 02:45:18 pm
Tony2ltr
  • 53
Governor adjust
« Reply #11 on: January 03, 2009, 02:45:18 pm »
Nope, I am talking about the Fuel screw (I have been doing some reading). I had cracked into it looking for power, but the car would not idle down, even with the idle screw backed all the way out so the accel lever wasn't even touching. The damn thing was a crop duster, I couldn't even see the street lights behind me, and the clutch would start slipping at about 25 PSI boost in third. I had been power shifting, and when I finally let go of the throttle, the R's stayed right where they were.  I ended up turning it back down because it was not driveable, but it HONKED!.
I have a bronze 6 puck clutch now, but I would love to get that power back!
This is an ecodiesel, so the boost aneurid was not even added to the pump until a later attempt at getting more power.
-Tony
Reply #12January 03, 2009, 03:42:32 pm
Governor adjust
« Reply #12 on: January 03, 2009, 03:42:32 pm »
Get a modified true turbo diesel pump and you'll get power closer to what you were experiencing. The LDA limits the bottom end fueling, which means more fuel when under boost
Reply #13January 03, 2009, 04:51:41 pm
Tony2ltr
  • 53
Governor adjust
« Reply #13 on: January 03, 2009, 04:51:41 pm »
What are the differeces in the TD (non-eco) other than the cold start linkage and the boost top?
