Author Topic: I think I made some rubber smoke!  (Read 6495 times)
October 14, 2008, 07:29:35 pm
rabbitman
  • 2788
« on: October 14, 2008, 07:29:35 pm »
Yeah, I got my new clutch put so I decided to see if it'd burn rubber. :roll:  So I stop in the middle of the road, rev it to about 3k rpm, engage clutch 'till it's draggin', floor the smoke pedal and then dump the clutch. Wow, I never dreamed I'd see the day, the tires lit up (sorta) and squealed like mad haha. They didn't stop squealing untill I ran out of rpms in 1st and I didn't bother tryin' 2nd. Anyways both tires made black lines and when I paced 'em I got 45ft for the passenger side and 48ft for the drivers side. :shock:  I never thought it could do that! haha. It must have a heavy flywheel I guess lol.
PS. There was more smoke coming out the tailpipe than off the tires. :lol:
Reply #1October 15, 2008, 09:46:14 am
spencebm
  • 686
« Reply #1 on: October 15, 2008, 09:46:14 am »
ha, hope you don't need another clutch
Ben Spencer
Reply #2October 15, 2008, 05:56:07 pm
  • 5104
« Reply #2 on: October 15, 2008, 05:56:07 pm »
impressive.
Reply #3October 15, 2008, 10:10:39 pm
blkboostedtruck
  • 1535
« Reply #3 on: October 15, 2008, 10:10:39 pm »
don't ya just love the torque of a diesel!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #4October 16, 2008, 01:15:32 pm
rabbitman
  • 2788
« Reply #4 on: October 16, 2008, 01:15:32 pm »
Duane
yeah now I gotta figure out how to make it burn in 2nd gear. 8)
Reply #5March 04, 2009, 11:03:16 am
« Reply #5 on: March 04, 2009, 11:03:16 am »
got a turbo on that thing? my rabbit burns all of second gear.. its got about 20 psi and crappy fueling.
Reply #6March 04, 2009, 12:30:20 pm
rabbitman
  • 2788
« Reply #6 on: March 04, 2009, 12:30:20 pm »
Not yet, I have a VNT-15 but don't have everything for installing it. My plan was to run a 2.25 inch exhaust front to back but I might just make a 2.5 inch down pipe for now and neck it down to the stock system 'till I can make the whole thing. I don't have the oil feed pipe or return either. I do have an LDA so that'll make things fun, except then I'll have to find some turbo injector lines.
Reply #7March 04, 2009, 06:48:05 pm
« Reply #7 on: March 04, 2009, 06:48:05 pm »
i took half of a TD line and half of the TDI line and slipped them into a piece of steel line just a bit bigger than the 2 lines and welded them together. i cut up my stock T3 oil drain and modified it also to work on the VNT17.
Reply #8June 08, 2009, 09:16:06 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
Re: I think I made some rubber smoke!
« Reply #8 on: June 08, 2009, 09:16:06 pm »
Before i ruined my clutch by doing this ...
I could do what you did in first then quickly slam it into 2nd and keep it going until i hit about 35km/hr (Actual speed, the speedo says like 50-60) when the tires grabbed and threw me forward to about 65 at which point the rpm im GUESSING is pretty high for 2nd.
Ed
