Author Topic: Question about IP pulley?  (Read 3086 times)
October 03, 2008, 02:29:19 pm
kibs45
  • 46
« on: October 03, 2008, 02:29:19 pm »
Hi I am currently swapping my ip pump out and have removed the bolt, but alas the pulley is still stuck are there any tricks to getting this off?  Thanks,
Joel
Reply #1October 03, 2008, 02:47:10 pm
blkboostedtruck
  • 1535
« Reply #1 on: October 03, 2008, 02:47:10 pm »
there is a special puller for that! you might be able to use a steering wheel puller?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2October 03, 2008, 03:31:29 pm
4KTD
« Reply #2 on: October 03, 2008, 03:31:29 pm »
If you want you can also put the nut back on a little and tap it with a brass/copper hammer while prying between the pump and the plate it was attached to with a prybar. This method usually works well for me,  don't go crazy with the hammer or prybar and watch your fuel lines.
Reply #3October 03, 2008, 03:48:31 pm
« Reply #3 on: October 03, 2008, 03:48:31 pm »
If you are changing the timing belt you can hit the sprocket where the timing belt is with a hammer. Don't hit it too hard though. Prying with a screwdriver at the same time does help. If you are hitting the sprocket with a brass punch or hammer, don't hit the edges of the teeth on the sprocket, you will damage them
Reply #4October 04, 2008, 12:01:52 am
Op-Ivy
  • 513
« Reply #4 on: October 04, 2008, 12:01:52 am »
And they will rip your belt apart! :(
Carefully prying with a screwdriver usually works for me.
Reply #5October 04, 2008, 02:53:45 am
ilikevwdiesel
  • 1202
« Reply #5 on: October 04, 2008, 02:53:45 am »
barbarians! don't beat on the pump shaft or pulley just get the proper puller...some dude from PA. was selling a nicely made unit for cheap on ebay, less than 20 bux. I bought one last summer it works great. until then I used a 2 jaw puller from sears cost less than 20 bux too.
My Bio
Reply #6October 04, 2008, 07:22:47 am
« Reply #6 on: October 04, 2008, 07:22:47 am »
As soon as I find a puller that fits, that's all I'd use
Reply #7October 04, 2008, 07:37:41 am
blkboostedtruck
  • 1535
'66 variant 1500S
Reply #8October 04, 2008, 09:23:42 am
Duster 5.9
  • 96
« Reply #8 on: October 04, 2008, 09:23:42 am »
i made my own puller. i would post pic, but i don't know how on this forum.[/img]
81 rabbit gas resting
81 rabbit cabby diesel n/a
85 jetta diesel n/a
85 golf diesel runs great
82 caddy diesel clean
82 caddy gas solid resting
and some parts cars
Reply #9October 04, 2008, 10:53:19 am
« Reply #9 on: October 04, 2008, 10:53:19 am »
Quote from: "Duster 5.9"
should get that posted in the FAQ :)  a DIY for home made tools
Reply #10October 04, 2008, 11:14:01 am
« Reply #10 on: October 04, 2008, 11:14:01 am »
Here's some instructions:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=13132
Reply #11October 04, 2008, 06:54:17 pm
Duster 5.9
  • 96
« Reply #11 on: October 04, 2008, 06:54:17 pm »
testing
85 jetta diesel n/a
and some parts cars
Reply #12October 05, 2008, 08:11:58 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #12 on: October 05, 2008, 08:11:58 am »
http://www.freewebs.com/midwisconsintaxidermy/apps/photos/album.jsp?albumID=2436862
I did this by using the URL button to link to the offsite URL.
Calvin
91 VW Golf 1.6NA 5spd
